Help with Security System
Old May 7, 2016 | 05:40 PM
Wranglin4Life's Avatar
Wranglin4Life
Default Help with Security System
Hi... Need some help please.
I have the buttonless fobs for my bike and for some reason the bike isn't recognizing either of them. I don't have the code to override it either.
I tried 31313 which apparently is the factory code but it's not working. Not sure what is wrong but I can't get the bike started.
Any help would be awesome.
Old May 7, 2016 | 05:48 PM
Smokey Stover's Avatar
Smokey Stover
Replace fob batteries. Then reset your PIN#
Old May 7, 2016 | 05:59 PM
Wranglin4Life
How do you reset the pin??
Old May 7, 2016 | 06:27 PM
cvaria's Avatar
cvaria
https://www.harley-davidson.com/en_U...er/file-5.comp
it's in your owners manual but see the link
Old May 7, 2016 | 07:07 PM
Eblank8's Avatar
Eblank8
default code for mine was the last 5 digits of my vin. if that works, change it
Old May 7, 2016 | 08:03 PM
bigbadpoppa's Avatar
bigbadpoppa
My default was 12345
Replace your batteries on your FOB. If one dies, the other one dies at the same time. That's because the fobs emits a signal 24/7, so if one battery is dead the other one is no better off. Or that's what wrench tells me. I always thought it was the other way around where the bike emits the signal 24/7. Apparently not?
Old May 7, 2016 | 08:49 PM
MikeySom's Avatar
MikeySom
my default was 87123 I was face timingwith my grandson and it appears the cell phone interfered with the key fob lights flashing couldn't shut it off until i removed the key fob far enough away and disarmed with my PIN I cycled the on off switch 3 times and hit the left turn signal three times to get the factory code( with the fob in hand )...Hope this helps I got it off a you tube video.
Old May 7, 2016 | 10:24 PM
Wranglin4Life
Thanks for the help. I switched the batteries out and I was able to get it fired up right away.
I tried a few times to reset the pin by following the directions posted and so far it's not working. Started to rain so I put the cover back on. Will try again tomorrow. Thanks again.
Old May 9, 2016 | 01:50 AM
sbarrale's Avatar
sbarrale
2nd Gear
My 2016 Heritage would start anytime. I even set a new pin #. Thanks to this forum, I turned the batteries around in my fobs and turned on the ignition. Now my security system works with no problems...The red light blinks and the blinkers flash...etc. The dealer installs the batteries in backwards in the fobs and forgot to tell me to turn them around.
flynavy
Nov 27, 2014 09:59 AM
ctf81549
Jul 1, 2011 08:42 AM
hddave2
Oct 15, 2008 07:38 PM
array
17
Apr 21, 2008 01:17 PM
Hiram
Sep 17, 2006 01:49 AM
