Rear Shock Adjustment
Old May 18, 2007 | 03:26 PM
Aroberts's Avatar
Aroberts
Default Rear Shock Adjustment
I have a 02 WG. Are my rear shocks pretty easily adjustable? When I have my girl on the back I sometimes bottom out. If they are adjust able where can I find what they should be set at with my 220 lb *** on them as well as adding my 120 lb girlfiend on there.
Thanks
Old May 18, 2007 | 03:34 PM
cadman311's Avatar
cadman311
Default RE: Rear Shock Adjustment
All you need is the tool. Moves easy, change when even you need to in a second.
Old May 18, 2007 | 03:53 PM
footpeg's Avatar
footpeg
You can grab the lower chrome skirt of the shock with your hands and turn it clockwise to adjust it up to accomadate more weight. It is not easy but I can do it. Just watch your fingers when the skirt turns. Itrotates about 1 inch, so leave room so your fingers don't get pinched. I have never tried to turn them back down by hand becuase I have never had to. The only reason that I know that it can be done by hand is because I could not locate my rubber strap tool so I tried it by hand and it worked.
Old May 18, 2007 | 04:17 PM
cadman311's Avatar
cadman311
Use the right tool
Old May 18, 2007 | 05:01 PM
Aroberts's Avatar
Aroberts
Thanks, I suppose I will have to head to the stealer and buy a $40 wrench if I ever want to lower it, ha-ha.
Is there a guage in the bike that tells youwhat setting it's inor is it just by feel and previous experience.
Old May 18, 2007 | 05:16 PM
TOMMAY's Avatar
TOMMAY
ORIGINAL: Aroberts
The spanner wrench is not that much,about ten bucks I think.
You probably got about five clicks of adjustment,the more shock exposed at the bottom,below the spring,the stiffer the ride. Just adjust both shocks all the way one way or the other and move each shock the same number of clicks til you're satisfied with the ride.
Good Luck
Tom
Old May 18, 2007 | 05:18 PM
SPECIAL ED's Avatar
SPECIAL ED
Nah no gauge just a series of "steps" on a ramp if you get underneath your shock and look up you can see what I'm talking about.The higher up the ramp you go the stiffer the ride and better the cornering clearance obviosly going lower has the opposite effect.Mine were at the lowest setting when I got it I cranked it up for clearance and ended up getting a better ride because it was bottoming out on the lowest setting.
Old May 18, 2007 | 05:19 PM
fj4069's Avatar
fj4069
i have the tool and it's easier to just use your hands and twist it. and i'm weak.
Old May 18, 2007 | 05:34 PM
Aroberts's Avatar
Aroberts
Thanks,
I guess I will start messing with it before I leave work today. I think because I am tall 6-4 I would want it the highest I can go but time will tell.
Thanks again
Old May 18, 2007 | 06:04 PM
SPECIAL ED's Avatar
SPECIAL ED
I could't get a good enough grip on mine to crank it up all the way with just my hands so I took an old Suzuki shock wrench I had laying around and modified it a little and it works great.I can throw my Street Bob around pretty good in the twistys without anything dragging but I don't have a back seat so I couldn't tell you how it rides two up.
