Bogs and backfires
Old Aug 4, 2016 | 07:30 AM
dfowler1's Avatar
dfowler1
Default Bogs and backfires
I have a 05 Superglide fuelie that cranks and runs fine until about half throttle. If you are riding it and twist the grip its like you cut off switch and a little backfire, let off and goes back to running fine. Will do it sitting still too. Any ideas???
Daniel
Old Aug 4, 2016 | 07:49 AM
mpescatori's Avatar
mpescatori
Running too lean ?
Old Aug 4, 2016 | 08:47 AM
Ghost_13's Avatar
Ghost_13
Daniel
It acting up under load (riding)..., how about when stationary and you rev it
Sounds like a timing issue to me (the backfire and bogging)
Ghost
Old Aug 4, 2016 | 09:46 AM
dfowler1's Avatar
dfowler1
I think its little lean and it will do it just sitting there.
Old Aug 4, 2016 | 09:53 AM
beanoboy's Avatar
beanoboy
First check the spark plugs and that will tell you if it's lean or rich...b.
Old Aug 4, 2016 | 10:22 AM
Max Headflow's Avatar
Max Headflow
Low fuel pressure. Could be plugged fuel filter or hole an internal line inside the tank. You can hear the fuel hissing out of the line if you pop the fuel cap and listen after the fuel pump stops running when the fuel level is low.
Mileage?
Old Aug 4, 2016 | 10:28 AM
dfowler1's Avatar
dfowler1
20k and plug look ok but problem just started with maybe 5 miles rode since.
Old Aug 4, 2016 | 09:31 PM
dfowler1's Avatar
dfowler1
Had a buddy bring his 05 over and swapped everything I could. I had give up but was looking at throttle body and never thought about MAP sensor, I just disconnected it and fired it up and it went to the rev limiter fast!!! So if you run into one that wont take the fuel at half to full throttle check the MAP....
Old Aug 5, 2016 | 08:55 AM
beanoboy's Avatar
beanoboy
Good stuff, glad you've solved the problem...b.
Old Aug 6, 2016 | 07:42 PM
Ghost_13's Avatar
Ghost_13
Sweet....
Ghost
edwardjtodd
Dec 11, 2017 11:04 PM
Lifeofchaos13
Oct 18, 2012 09:24 AM
robbie52
Jul 18, 2010 06:38 PM
ecaldwell78
Jun 29, 2009 01:43 PM
montana dan
Aug 27, 2007 11:13 AM
