ABS light on ?
Old Mar 22, 2017 | 05:11 PM
Jeff47's Avatar
Jeff47
1st Gear
Default ABS light on ?
ABS light staying on when riding. Any suggestions? 08 Dyna
Old Mar 22, 2017 | 06:53 PM
Smogbob's Avatar
Smogbob
Possible broken wire on the sensor, look to see if you get any error codes like this.
Here is the code: DTC: C1032
FAULT CONDITION: Front wheel speed sensor circuit open or shorted
Old Mar 25, 2017 | 07:57 AM
Great08's Avatar
Great08
Hello...I've had my '08 SuperG since new. It currently has about 82K miles. At about 50K, when jump-starting it, I inadvertently hooked cables wrong. Luckily, no real harm done. However, ever since, the ABS light stays on. My bike is not equipped with ABS. I had local shop check it out, and was told not to worry about it, that it means nothing.
Old Mar 25, 2017 | 01:35 PM
Nickd2689's Avatar
Nickd2689
Maybe the dealer can reconfigure the bcm for not having abs? At work (Chrysler tech) we can add or remove various vehicle options when a customer wants to add a factory accessory that wasn't on their vehicle from the factory. Like heated seats for example. Anyway it might be worth asking the dealer if they can do something like this. Either way a dtc would be helpful.
rossWG
Aug 3, 2021 09:56 PM
Just Me
Mar 4, 2012 08:02 PM
ssaa426
Feb 13, 2012 01:10 PM
glide2005
Jan 17, 2011 11:56 AM
okieblue62
Aug 1, 2010 03:10 AM
