Ok ... I understand now ... the fitting on top of the turn signal comes apart ... you can attach the upper part of the fitting to the bolt then attach the turn signal to the fitting ... just separate the two larger nuts on the turn signal
I really must be dense. I can unscrew that and then i have the turn signal, the fitting and the mirror. I still cant for the life of me figure out how this all screws in when I cant rotate the mirror and cant rotate the turn signal
you don't remove it from the signal ... unscrew the larger nuts where your fingers are in the photo ... that comes apart ... the top part of the fitting attaches to the bottom of the mirror ... the rest attaches to the signal ... then you screw them together ...
