2017 FXDL cables for new risers
Hi All,
Maybe some of you guys could help me out. I want to put some 8" risers on my 2017 FXDL. I already swapped out the stock bars with Lucky Dave's riser bars (love 'em). However, the stock risers are a bit low. I know I need a FXDB mount style front light housing (local HD dealer want 2 hundo for - rip off). The throttle, clutch and brake lines will need to be longer,. also the parts guy at HD said I needed an extension for the wiring to both sides (not sure if that's correct though) - I have not measured how long they are now. The HD dealer wanted like $868.00 for everything excluding the new risers (I didn't care for the ones they had).
I'm sure there are a lot of you that have swapped out for taller bars on your Low Rider. If any of you have a better hook up with realistic prices I would appreciate it as there is no way in God's green earth I'm gonna shell out that much $$... and I really want the Big Al's risers. Thanks in advance for your reply's.
https://www.magnumshielding.com/
Once you figure out what you want/need,, find an indy that's a Drag Specialties dealer and order from them to save a little more.
