how do you fix bcm code b2121,
Old Jul 15, 2017 | 04:37 AM
widey's Avatar
widey
Stage I
Default how do you fix bcm code b2121,
harley davidson FXDWG 2015 , WILL NOT START ,CAN JUMP SOLENOID TO BATTERY IT STARTS , ERROR CODE B2121 , STARTER OUTPUT OPEN ? HOW DO YOU FIX
Old Jul 15, 2017 | 05:51 AM
Northbound Southerner's Avatar
Starter relay?
Old Jun 15, 2018 | 11:28 AM
TGR2016's Avatar
TGR2016
Stage II
2013 FXSB. I have the exact same problem. Anyone?
Old Jun 16, 2018 | 07:23 PM
Jay Guild's Avatar
Jay Guild
It is seeing the switch so I'd look at the starter relay. Is your neutral light coming on in neutral?
Old Jun 17, 2018 | 04:47 AM
TGR2016's Avatar
TGR2016
Stage II
Neutral light is on. Have checked clutch in, kickstand and other possible combinations, but no go. Fuel pump runs and all lights are as normal when I turn the ignition and Run switch on, but when pushing the start switch, the headlight goes off then nothing. Checked and found a slightly pinched cable in the RHCM. Fixed this, cleared all codes and tried again. Still nothing.
Starts if I jump it from the starter relay plug to the battery. Now there are two DTC's left on the BCM diag. B2121 (Starter Output Open/BCM Malfunction?) and B2122 (Starter Output Shorted High?).
Old Jun 17, 2018 | 11:03 AM
Jay Guild's Avatar
Jay Guild
Pull the relay and do continuity tests on the posts. The only other thing it sounds like it could be is is a pinched wire from the start switch.
Old Jun 17, 2018 | 01:27 PM
MORT666's Avatar
MORT666
Fuse ? side stand switch.
Old Oct 7, 2018 | 06:03 AM
Xavier24's Avatar
Xavier24
Stage III
Where is located the starter relay ? and the fuses on a FXDB 2014 ?
Old Mar 16, 2019 | 05:15 AM
bdibs's Avatar
bdibs
Stage III
hello dear,
how was this issue solved? I am facing the same problem on my FLD 103 2014
Old Mar 16, 2019 | 10:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I believe the starter relay and system relays are the same, swap them out and check to see it starts.
