Rusty studs
Old Oct 24, 2017 | 09:57 PM
Vec's Avatar
Vec
the PB blaster worked, all 4 came off no problems.
air cleaner and power vision installed today, new S&S exhaust will be here tomorrow, this evening i went to the hardware store and picked up new nuts for the install tomorrow evening.
Old Oct 25, 2017 | 05:40 AM
JayStronghawk's Avatar
JayStronghawk
Originally Posted by Vec
The PB blaster worked, all 4 came off no problems.
Blaster is my First Option, usually works if it don't Heat and Blaster Both, never had a problem going that route ..
Old Oct 25, 2017 | 09:38 AM
jdvorchak's Avatar
jdvorchak
If you plan on using anti-seize, use only the high temp "copper" anti-seize on those exhaust studs. The "silver" will turn into hard glob and won't do the job you intended.
Old Oct 25, 2017 | 12:15 PM
Vec's Avatar
Vec
I do have both types I’ll have to look at my copper to see exactly the temperature rating on it but thank you very much for the heads up!
Old Oct 25, 2017 | 03:51 PM
jdvorchak's Avatar
jdvorchak
I'll bet it's higher than the silver. I work on BMW especially old "airheads" and I've learned to use the copper on the exhaust parts. Never failed me yet. I have seen the silver glob up and fail on those same parts.
Old Oct 25, 2017 | 06:36 PM
Vec's Avatar
Vec
ok, the copper base is 2000deg, the aluminum base is 1600deg, thats not much but I'll use the copper...
update:
UPS still has not delivered my frickin exhaust.. still shows "out for delivery"...
sons of bitches...
Old Oct 25, 2017 | 10:33 PM
Blue Bob's Avatar
Blue Bob
Originally Posted by 1957buick
pb blaster is good , spray some on them heat with a heat gun, spray while hot repeat 2-3 times and then tighten and loosen slowly going both ways they will come off but use a small wire brush ,like a 1/2 fitting brush for copper patience is the key !!
I am faced with this problem almost weekly in other situations. Many times by the time I see it there's a broken easy out or tap to deal with, then the customer asks why it took an hour?
Penetrating oil along with heat helps a lot! Everyone seems to have very good suggestions!!
I would use high heat as a last resort.
42 yrs experience and still learning.
Old Oct 25, 2017 | 11:48 PM
cggorman's Avatar
cggorman
Based on my experiences at work where we built systems with 15+ year service lives in harsh environments, I use Loctite LB-8009 heavy duty anti-seize. It's metal free, graphite based, good for all metals (copper with aluminum is bad), and good to 2300F...
http://na.henkel-adhesives.com/produ...=8797877895169
Old Oct 26, 2017 | 12:22 AM
Blue Bob's Avatar
Blue Bob
copper with aluminum bad, can you tell us more?
Thanks
Old Oct 26, 2017 | 12:25 AM
Blue Bob's Avatar
Blue Bob
Amazon Amazon
