Dyna Clutch Interchangeability
Old Jul 30, 2018 | 11:31 AM
5mel4's Avatar
5mel4
5th Gear
Default Dyna Clutch Interchangeability
Is there any difference dimensionally between the 2007-2010 vs. the 2015-2017 clutch assemblies and would the later clutch be able to be retrofitted to the earlier bikes. One difference appears to be an improved inner clutch hub with a cast in center to stop it from coming loose. I can't find any information on parts interchange for a 2009 Dyna Fat Bob.
Old Jul 30, 2018 | 02:21 PM
crusader1xxx's Avatar
crusader1xxx
Not 100% sure but there might be some changes to the main transmission shaft...would have to check part numbers....
i would go to Ronnie’s HD parts finder. And pull the clutch/ trans parts numbers and compare. If it’s the same then I would think it can be switched. Q. Is this a cheaper option then say a baker or other high end after market clutch?
Old Jul 30, 2018 | 04:08 PM
5mel4's Avatar
5mel4
5th Gear
I have the 2009 Dyna parts book and part numbers differ for sure for the clutch hub, but a lot of the other parts are the same. I wondered if, in spite of that, whether there was any physical or size difference, with the new part numbers simply strengthened for the later engines. The reason is there is a low mile takeoff available for a good price and if it fits, may be worth getting.
ReverendBell
EVO
16
May 15, 2016 09:50 PM
jammerx
EVO
Mar 10, 2014 07:07 PM
educatedxanarchist
Dec 7, 2008 10:18 AM
HDF Tech
Aug 26, 2005 12:21 PM
skywagon
Jul 18, 2005 12:07 AM
