Voltage
Old Sep 12, 2018 | 03:03 PM
Tileman2692's Avatar
Tileman2692
Default Voltage
Im reading 13.60 volts while riding is that where it should be
Old Sep 12, 2018 | 03:14 PM
MURPHCC1's Avatar
MURPHCC1
depends on the gauge......stock ones are notorious for being off........and you'll find most gauges that way........if it has always shown that and no problem with the bike, then just use that as your baseline.........
Old Sep 12, 2018 | 03:23 PM
Tileman2692
It's on my PV1 I just got back. Didn't put it on my gauges display before, so it's a first
Old Sep 12, 2018 | 03:42 PM
MURPHCC1's Avatar
MURPHCC1
ok.......could be off a volt..........mine is running about 14.5v at speed..........12-13 at idle.
If you didn't have a problem before with it and just now finding out the voltage.......like I said........use that as baseline and if it changes too much you'd have a problem
Old Sep 12, 2018 | 04:04 PM
Tileman2692
Cool! Thanks
Old Sep 12, 2018 | 09:10 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Anywhere from 13.6-14.5 and you're good to go!
Old Sep 13, 2018 | 04:50 PM
Tileman2692
Thanks
Old Sep 13, 2018 | 05:10 PM
NORTY FLATZ's Avatar
NORTY FLATZ
At what RPM?
Idle?
Old Sep 13, 2018 | 08:03 PM
OldEnuf2NoBtr
Originally Posted by NORTY FLATZ
At what RPM?
Idle?
@ 13.6 at idle
@ 14.5 at throttle
Old Sep 14, 2018 | 09:46 AM
MURPHCC1's Avatar
MURPHCC1
I get 14.5v at speed.........12.7v at idle.........and there's nothing wrong with that.
