first service cost
Old Dec 6, 2018 | 09:35 PM
Huggerbugger's Avatar
Huggerbugger
One guy said all the Harley dealer does is park it in back for a few days, then call you and tell you it's done.
Old Dec 6, 2018 | 09:53 PM
VAFish's Avatar
VAFish
If you don't know how to do maintenance on your bike, how would you know the difference?
Old Dec 6, 2018 | 09:57 PM
Huggerbugger
Thumbs down
Built a few choppers, restored some vintage bikes, just don't get a kick out of wrenching any more. Nothing but a pain in the ***.
Old Dec 6, 2018 | 10:32 PM
VAFish's Avatar
VAFish
Right, Understand your sentiment, sometimes the joy in working on bikes is no longer there. But, you know how to do maintenance and would be able to check to see if the dealer did a service or not. Or at least you would know to check the oil, trans and primary and see if it looked like it have fresh oil in it.
Someone with no mechanical skills and no experience doing their own maintenance on their bike wouldn't know if a dealer did the first service or just parked it behind the shop for a couple days.
Old Dec 6, 2018 | 11:00 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by Tank1844
What is the cost for the first service on a 2018 Street Glide?
IF the dealership does everything correctly, than $300-$400 should cover it.
If they do it wrong, it can cost you your life...
Old Dec 7, 2018 | 04:50 AM
JayStronghawk's Avatar
JayStronghawk
This is what's supposed to be done what they actually do have to trust your Dealership ..
Maintenance checklist for Sportster, Dyna, Softail and Touring models
  1. Change engine oil and filter. Clean magnetic drain plug and install new O-ring.
    20W50 ______ SYN-blend ______ SYN3® oil ______
  2. Inspect oil lines and brake system for leaks, contact or abrasion. 1,3
  3. Inspect exhaust system for leaks, cracks, and loose or missing fastners or heat shields. 3
  4. Inspect tires, tread depth and adjust pressure.
    Front: ______ Rear: ______ (tread depth)
    Front: ______ Rear: ______ (pressure)
  5. Check torque on wheel spokes, if equipped (Dyna® and Softail® models). 1,5
  6. Change primary chaincase lubricant. Clean magnetic drain plug and replace O-ring.
  7. Change transmission lubricant. Clean magnetic drain plug and replace O-ring.
  8. Check Clutch adjustment (Dyna® and Softail® models). 1
  9. Check level and condition of clutch fluid (CVO™ model). 1,4
  10. Inspect drive belt and sprockets; adjust belt. 1
  11. Check throttle, brake and clutch controls; adjust and lubricate (Dyna® and Softail® models). 1
  12. Check and lubricate brake and clutch controls; adjust as needed (CVO™ model). 1
  13. Inspect and lubricate jiffy stand. 1
  14. Inspect fuel lines and fittings for leaks, contact or abrasion.1,3
  15. Inspect break fluid sight glass. 4
  16. Inspect break pads abd discs for wear.
  17. Check operation of electrical equipment and switches.
  18. Adjust steering head bearings (Dyna®1,2, Softail®1, Springer®1 and CVO™1 models).
  19. Adjust rocker bearings (Springer® models1,6).
  20. Check torque on critical fasteners (Dyna®1, Softail®1,3 and CVO™1 models).
  21. Inspect, clean and tighten battery connections annually.3
  22. Check baterry voltage. ______
  23. Road test to verify component and system functions.
    ______ miles
Reminder: Lubricate steering head bearings every 2,500 miles (4,000 km) (Springer® models).1,7
Notes:
  1. Should be performed by an authorized Harley-Davidson® dealer, unless you have the proper tools, service data and are mechanically qualified.
  2. Disassemble, lubricate and inspect every 30,000 miles (48,000 km).
  3. Perform annually or at specified intervals [30,000 miles (48,000 km) for CVO™ FLSTSE2] whichever comes first.
  4. Replace DOT 4 hydrualic brake/clutch fluid and flush system every two (2) years.
  5. Perform spoke tension check at the 1,000, 5,000, 20,000 mile services (1,600 km, 8,000 km, 32,000 km) and every 15,000 mile (24,000 km) interval thereafter. Not all vehicles are equipped with spoke wheels. Consult appropriate topic in service manual.
  6. Adjust at 500 miles (800 km).
  7. Disassemble, lubricate and inspect every 20,000 miles (32,000 km).
Gaffy52
Mar 6, 2013 08:22 AM
ADay73
Dec 14, 2012 09:15 AM
gseely
Aug 17, 2010 01:49 AM
cdesero
Mar 20, 2010 06:12 PM
KSGLIDEGUY
May 7, 2008 12:55 PM
