Engine knocking when hot
Old May 7, 2019 | 11:20 AM
PMitch's Avatar
PMitch
Stage II
Default Engine knocking when hot
I have a 95 wideglide with an Evo motor. I had a leak as the cam cover gasket was junk. I replaced the gasket and now when the motor gets hot it knocks. Any ideas? I did change the oil and there is no metal YET so I am hoping its not terminal. I am new to working on bikes so I am kind of lost. Thinking maybe possibly I have the timing off when I reassembled??
Old May 7, 2019 | 12:56 PM
Mattbastard's Avatar
Mattbastard
That's a good guess. Since you took the cover off you certainly had to pull the timing cup and sensor, which means if you never set the timing when you put it all back together you could have way too much advance, hence the knocking.
Old May 7, 2019 | 02:36 PM
Tommy C's Avatar
Tommy C
Did you use the wrong gasket & block off the oiling passage to the crankshaft? Time to take it apart & double check your work before you grenade the bottom end.
kaiser343
Engine Mechanical Topics
Sep 25, 2013 03:52 PM
skully1200
Feb 7, 2012 07:34 PM
bubba626
Jun 23, 2010 04:09 PM
dog155
EVO
Apr 13, 2007 03:49 PM
