Switchback turn signal relocation
Old May 19, 2019 | 08:11 AM
Dfgunner's Avatar
Dfgunner
6th Gear
Default Switchback turn signal relocation
I’m sure it’s been asked before. Anyone move their front signals to the lower triple trees? Can you still use the factory windscreen and what parts are needed?
Old May 19, 2019 | 08:54 AM
Krash26's Avatar
Krash26
I did move mine to mount a Dead Center batwing fairing. They included the hardware for that when I bought the fairing. Its was super easy to do that and this fairing used the existing quick release mounting hardware for the OEM windshield too. So, I'm pretty sure you can continue to use the existing windscreen. Hope that helps....
Old May 19, 2019 | 09:04 AM
Dfgunner's Avatar
Dfgunner
6th Gear
Default Sweet
Excellent, thank you
Old May 19, 2019 | 07:56 PM
tgmotoman's Avatar
tgmotoman
Yes you can, and the easiest and cleanest way is to remove the original bolt from the lower mounts on the forks and replace them with exhaust studs, I believe studs from a road king works, been a few years since I did it. They threads are different on the studs. Works great.
Old May 19, 2019 | 09:10 PM
Dfgunner's Avatar
Dfgunner
6th Gear
Default Thank you
I’ll get some at the dealership this week.
Old May 19, 2019 | 09:37 PM
Dfgunner's Avatar
Dfgunner
6th Gear
Default Exhaust studs
@tgmotoman, are those the exhaust studs into the heads? What year should I ask for?
Old May 20, 2019 | 12:18 AM
tgmotoman's Avatar
tgmotoman
Old May 20, 2019 | 06:37 AM
Dfgunner's Avatar
Dfgunner
6th Gear
Default Just ordered
Gotta love Amazon
Old May 30, 2019 | 08:42 PM
Dfgunner's Avatar
Dfgunner
6th Gear
The RoadKing exhaust studs worked great. Perfect solution to the problem.
Mott77
Apr 26, 2017 07:35 AM
street glide rider
Sep 6, 2016 06:04 AM
Techgnosis
Mar 19, 2014 04:30 AM
emerican19
Jan 24, 2012 11:12 PM
venturalocal69
Feb 27, 2010 02:47 AM
