Riser Extensions
Old Jun 21, 2019 | 04:57 AM
Mountaineer Rider's Avatar
Mountaineer Rider
6th Gear
Default Riser Extensions
Hey I was wondering if I could get away with adding 2” riser extensions with a stock bar set up and not have to change any cables. I have a ‘11 fxdc with the buckhorn bars. I know there is some variability there but was wondering if anyone has done this with an all stock setup. Thanks
Old Jun 21, 2019 | 05:39 AM
FreedomRider's Avatar
FreedomRider
I have not done this but there should be enough slack that you shouldn't have any problems …
Old Jun 21, 2019 | 06:08 AM
Antonio Balls's Avatar
Antonio Balls
I own a 2013 FXDC and added a riser with no problem. It raised the bars up and back a bit. Made a world of difference.
Old Jun 21, 2019 | 06:39 AM
Architect's Avatar
Architect
Fair amount of slack in all of the cables and wiring, I would assume 2" would work out with limited drama. Good luck.
Old Jun 21, 2019 | 01:17 PM
kcfocust's Avatar
kcfocust
2" should be fine
I think its when you start adding 3" plus you have to worry
Old Jun 21, 2019 | 03:11 PM
cvaria's Avatar
cvaria
No idea what you are riding... You will have no issues going up two inches. There's enough slack.
I loved it
Old Jun 21, 2019 | 03:22 PM
Mountaineer Rider
6th Gear
Thank you for the info guys. I will be buying some from DK soon then. It will be an easier way to get some height without messing with much.
Old Jun 21, 2019 | 03:23 PM
packmen21's Avatar
packmen21
+1
Old Jun 22, 2019 | 06:37 AM
beanoboy's Avatar
beanoboy
Don't forget to buy longer 'riser bolts' !
Old Jun 22, 2019 | 08:40 AM
pab3rd's Avatar
pab3rd
If he buys from DK, longer bolts come with the extensions.I bought 2" extensions to go with my 5 inch risers. And the longer bolts came with the extensions. On a side note; if you have stock risers you need the fat riser extensions. As the others work with 1" risers.
