Riser Extensions
Old Jun 22, 2019 | 11:03 AM
Mountaineer Rider's Avatar
Mountaineer Rider
6th Gear
Good to know. They will be going on with a stock riser. Thanks
Old Jun 24, 2019 | 08:01 PM
Pylot7's Avatar
Pylot7
I have a 2011 FXDC, put a 2 inch riser with a 1 inch pull back.
No issue with cables.
Old Mar 18, 2020 | 08:54 AM
vistavette's Avatar
vistavette
Originally Posted by Antonio *****
I own a 2013 FXDC and added a riser with no problem. It raised the bars up and back a bit. Made a world of difference.
Reviving an old thread. I just picked up a 2008 FXDC and need to add risers. Can you tell me what risers you're using/where you got them?
Old Mar 18, 2020 | 09:44 AM
Mountaineer Rider
6th Gear
I just have my stock 2011 fxdc risers with DK Customs 2” riser extensions. They came with all hardware needed. I used stock riser bushings but should have at least got some polly ones as there is a little slop. Also measure the circumference of the bottom of your riser. I got the “fat” one but they are way wider than I needed for that riser.
Old Mar 18, 2020 | 10:33 AM
vistavette's Avatar
vistavette
Do your riser extensions give you more pull back and height; or just height?
Old Mar 18, 2020 | 11:03 AM
Mountaineer Rider
6th Gear
They mostly gave me height. I’d say the feel is maybe slightly more pulled back but that was minimal IMO. If you want more than just a slight pullback you are better off going with a riser that has the height and pullback you are looking for.
Old Mar 18, 2020 | 11:41 AM
NOMOREWORK's Avatar
NOMOREWORK
I used Harley risers on my 09 Lowrider and they worked fine. I think they were 2 inch .
Old Mar 18, 2020 | 03:10 PM
vistavette's Avatar
vistavette
i looked up risers on the HD site and it doesn't appear that they offer them any longer.
TechSlave 71
May 13, 2019 06:27 PM
Joey Pennington
General Topics/Tech Tips
Jul 30, 2016 11:00 PM
VHinch
Jul 1, 2015 01:17 PM
Werdna
Sep 6, 2012 11:21 AM
DynaRyda06
Jul 18, 2010 10:36 PM
