Help
Old Jul 4, 2019 | 09:12 PM
Dave Praska's Avatar
Dave Praska
1st Gear
Default Help
I'm on a road trip and I made the big Mistake of pressure washing my bike which is an 09 Dyna low rider Now when I'm riding it'll start popping and Cutting out and then it will come back real quick I've looked at all the connectors they're dry the air cleaner was a little wet and there with black soot And a little moisture so I cleaned that area and left their filter off road down the road still popped Look at the kill switch everything seems fine there Reading different threads that almost acts like a fuel filter but I don't know how spraying it with water would cause a fuel filter to go out any help would be appreciated
Old Jul 4, 2019 | 09:47 PM
Black2012beast's Avatar
Black2012beast
3rd Gear
Did you check your battery connections?
Old Jul 4, 2019 | 09:59 PM
Dave Praska
1st Gear
Default Thanks
No I will definitely check them right now
Old Jul 4, 2019 | 10:11 PM
Dave Praska
1st Gear
Default Checked that
My negative cable was really loose tightened that going to take it for a spin here in a second man I hope that was it thanks again will let ya know if it fixed it
Old Jul 4, 2019 | 10:21 PM
Black2012beast
3rd Gear
I found that on my Wide Glide that loose battery connections cause all sorts of problems.
Old Jul 5, 2019 | 11:03 AM
Dave Praska
1st Gear
Default Thanks
Took it for a spin problem solved thanks again your a lifesaver
Brian McCabe
Dec 29, 2014 03:35 PM
Trial dog
Jul 8, 2013 11:18 AM
jordanball33
Apr 30, 2012 06:34 PM
champ198
Oct 20, 2010 07:27 PM
jeffwest5599
Exhaust System Topics
Aug 13, 2010 12:39 PM
