tire pressure
Old Jul 19, 2019 | 08:05 AM
hell hound's Avatar
hell hound
32f/36r
the recommended tire pressures from vehicle manufacturers are usually pretty stupid
Old Jul 19, 2019 | 08:22 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
30 lbs. front 40 lbs. rear and 32f/36r
Only two replies that appear to pertain to the OP's bike. I wonder which is correct?
Old Jul 19, 2019 | 08:38 AM
hell hound's Avatar
hell hound
the correct pressure is the one that the bike feels best, handles best, brakes best and wears the most even. All these things are different for each bike based on your weight, passenger, luggage, altitude, temperature, what tires you have, riding style
you just have to experiment alittle, these things aren't set in stone but I can assure you that 32/36 is a good place to start and then adjust from there
maybe this guy weight 50 lbs heavier than me and has saddle bags and his bike feels best at 32/40
Old Jul 19, 2019 | 09:44 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Neither!
I already posted the correct pressures.
/thread
Old Jul 20, 2019 | 08:06 AM
470004's Avatar
470004
Originally Posted by hell hound
32f/36r the recommended tire pressures from vehicle manufacturers are usually pretty stupid
the correct pressure is the one that the bike feels best, handles best, brakes best and wears the most even. All these things are different for each bike based on your weight, passenger, luggage, altitude, temperature, what tires you have, riding style you just have to experiment alittle, these things aren't set in stone but I can assure you that 32/36 is a good place to start and then adjust from there
+1...
Old Jul 22, 2019 | 07:52 AM
POOK_HD's Avatar
POOK_HD
Default Manual says...
The manual says 30 Front / 40 Rear. It should be listed on the right side downtube as well (unless some knucklehead took that off). https://ownersmanuals2.com/harley-da...s-manual-66706
18Slim
2018+ Softail Models
Jul 27, 2019 11:31 AM
BigDogIdaho
May 11, 2016 04:09 PM
pretz
Mar 9, 2015 10:09 AM
seniorsuperglideE8
Jan 25, 2015 02:21 PM
Sharkman73
Feb 20, 2012 07:17 PM
