Wiring Problem?
Old Jul 15, 2007 | 11:32 AM
tman715's Avatar
tman715
6th Gear
Default Wiring Problem?
I just added about 4 inches of wire to my indicator cluster to go to risers and drag bars and for some reason, both my turn signal indicators do not work. I meticulously rewired each individual wire one at a time to make sure I did not booger anything up but when I put it all back together the signals themselves are working but the indicators aren't. The oil indicator and neutral indicator are coming on just fine. I guess my question is are these leds? and if so could I have burned them up when soldering. I was certain I did the soldering downstream far enough away from the cluster and nearest to the harness as I could. Any input?
Old Jul 15, 2007 | 05:39 PM
mud's Avatar
mud
Default RE: Wiring Problem?
I do not believe they are led tman.
Retrace and go over all of the work you did on the wiring.
More than likely you will find the problem here.
May be a pinch somewhere.
mud
ORIGINAL: tman715
jamesw1301
Jul 23, 2018 08:38 PM
BMCsteve
Mar 28, 2018 03:18 AM
92oldskoolxlh
Apr 28, 2013 10:59 AM
UncleChey
Electrical/Lighting/Alarm
Feb 14, 2011 04:31 PM
JDixon
Jan 29, 2008 11:27 PM
