Dyna FXR
Old Jan 1, 2020 | 12:41 AM
fxdlx's Avatar
fxdlx
I like it. He's looking for more wrecked FXDLS's to rebuild with the fxr copy rear frame.
Old Jan 1, 2020 | 01:32 AM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by rbdub474
I have this one I'm going to build up soon. I have a S&S TC 124" and a Baker 6 for it already. Will be doing performance suspension, brakes and paint. Should be a fun little ripper.
That's a $10-12K bike out here as it sits, FXR's of any variation bring good $$$, anything under $7000 you can bet been run to **** or gomered up by SOA wannabe's.
Old Jan 1, 2020 | 10:31 AM
Y2K's Avatar
Y2K
Originally Posted by Durham man
My 92 super glide. The biggest plus that an fxr has over a dyna is the weight. The stiffer frame, better swing arm set -up are all great, but the one thing that can not be matched by a dyna is the weight factor.
I had an early '84 FXRS,correct me if I'm wrong but I believe it was the lightest modern big twin H-D ever made at just 575lbs..
It was a dry clutch/chain drive bike like a Shovel but had the early Evo motor,often regret letting it go.
Old Jan 1, 2020 | 12:59 PM
Durham man's Avatar
Durham man
[QUOTE=Y2K;18771769]I had an early '84 FXRS,correct me if I'm wrong but I believe it was the lightest modern big twin H-D ever made at just 575lbs..
[/QUOTE you are probably right about it being The lightest big twin. 575 is only 25 more pounds than a sporty! I believe my 92 weighs in at 600.
Old Jan 1, 2020 | 03:51 PM
multihdrdr's Avatar
multihdrdr
575 Lbs ... sounds about right ( "Dry" )
DurMan, your '92 Specs out the same ...
Old Jan 1, 2020 | 04:44 PM
cggorman's Avatar
cggorman
Porker. LOL!
Old Jan 1, 2020 | 05:32 PM
brownie4412's Avatar
brownie4412
Originally Posted by Highwaymans
The sketchy rep that dude had with his old choppers..... WTH would any one trust him to do that stuff to a perfectly fine dyna frame? Pass.....
Do tell.... I’ve always found it odd that it’s a “chopper” company with a seemingly total focus on the Dyna scene.
Old Jan 1, 2020 | 06:22 PM
rbdub474's Avatar
rbdub474
Originally Posted by cggorman
Seems like somebody else has done this. Also seem to recall somebody splicing an M8 into an FXR.
Jeff Holt did a M8 one. I think it was a 158” motor.
Old Jan 1, 2020 | 10:24 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Originally Posted by beanoboy
O.P. I can't see from the pic. what is being done to that FXR.
BBC added a custom rear section to a Dyna frame.
Dave
Old Jan 1, 2020 | 11:07 PM
fxdlx's Avatar
fxdlx
I don't particularly like BBC. I don't like their mounts. But he didn't put a TC in an FXR. He put a hand built FXR style rear frame section on a wrecked FXDLS frame. I would imagine it's longer than an FXR. And definitely weighs more, probably more than a Dyna. Thats a dyna engine antrans in there.
And yes I saw someone was building an M8 FXR.
