smogger
Old Jul 21, 2007 | 07:10 PM
shortfatboy's Avatar
shortfatboy
Default smogger
The Dyna Low I recently purchased was a California model, and has a smog device/canister, and vacuum lines from/to the gas tank, and a vacuum line to the carb. Has anyone successfully removed the smog system and if so how did it change the fuel mixture/jetting needs.
Old Jul 21, 2007 | 09:23 PM
07bobber's Avatar
07bobber
Default RE: smogger
id like to know the same for my bike
Old Jul 21, 2007 | 09:28 PM
shortfatboy
Default RE: smogger
mine has a carburetor, I was told by a source to just plug the vacuum port at the carb, and plug the nearest line at the tank...not sure how fuel injection systems bypass the smog can...
Old Jul 21, 2007 | 10:20 PM
grizzly's Avatar
grizzly
Default RE: smogger
What exactly does that can do? I have it on my bike as well, and it is butt-ugly....
Old Jul 21, 2007 | 11:14 PM
darkdyna06's Avatar
darkdyna06
Default RE: smogger
The can (charcoal canister) collects the vapors that come from the gas tank vent, filters them, then puts them into the intake manifold. Believe it or not, it has no effect on jetting at all. Do not plug the line that comes out of the tank or else the pump (fuel injected) or carb will starve for fuel. On my 06, the vent line from the tank has a check valve in it, so you can just leave it open after the check, disconnect the line on the intake and plug the fitting, and remove the whole can with the plastis hoses intact. If you push down the tab on one side of the can, it slides right out sideways, do not I repeat Do not remove the two allen bolts underneath it, or you will be un doing the front motor mount.
Old Jul 21, 2007 | 11:41 PM
mentor70's Avatar
mentor70
Default RE: smogger
^^^ Did that
I almost crapped myself when that 88 droped two 2 inches!
Old Jul 22, 2007 | 05:00 AM
shortfatboy
Default RE: smogger
Thanks darkdyna!
Old Jul 22, 2007 | 05:20 PM
grizzly's Avatar
grizzly
Default RE: smogger
Sounds good, mine is comming off this week!
Old Jul 22, 2007 | 07:20 PM
DYNAMITE 1's Avatar
DYNAMITE 1
Default RE: smogger
Did anyone get an engine light or anything coming on after they removed it? Thanks
Anixon88
Exhaust System Topics
16
Jul 27, 2022 06:17 PM
jerseydevil63
Aug 16, 2014 10:01 AM
LawDawg79
Mar 8, 2011 08:09 AM
powg
Aug 21, 2010 01:51 AM
Beefcake
Nov 10, 2005 02:51 PM
