My 2003 super glide keeps dying lime it’s running out of gas. Was out the other day and everything was fine and then it’s just died. Let it sit for 10 minutes and it fired right back up and rode for about 2 minutes before it did it again. Did it like ( times before I coasted into my driveway. No electrical problems, just seemed like it was running itself out of fuel.
All good suggestions, sometimes the vent in the gas cap will get clogged and prevent the gas from flowing. The loosening of the gas cap is a valid one.
I had my crank position sensor go bad on me a few years ago. I'd ride it until it got hot, then it would just die. Then after waiting a few minutes it would run, then die when it got hot. If I ran it hard at higher rpm it shut down faster (heat), if it babied it at super lower rpms it would go quite a bit longer. That might give you and idea as to whether or not it's a heat issue.
Thanks for sharing this useful info!
