2008 Super Glide 8" Riser Question
First of all i did use the search option but i was getting mixed information. I have 08 super glide and I want to install 8" risers with sportster bars, will stock cables and brake line fit? or do I need longer cables? If i do need longer cables will street bob cables fit since a street bob came stock with mini apes?
IF 8" risers and Sportster bars work out to equal the same height as mini apes, you'll need street bob throttle cables but the clutch should work by running it behind the triple trees.
I have mini apes on my FXD and that's all I had to change.
My apologies, I forgot about the brake line. I had to change that too using a street bob line. My mini apes are 10 inch. HD part# 56079-93
cknight98
Jun 20, 2011 10:22 AM
