Hi all
Got this problem going on with my 2011 fatbob . When I try to press the start button there nothing and on my dash the indicator lights flash alternatively,just wondering anyone else have the some problem happen and whats the solution??
No changed fob battery, changed battery, changed main fuse, its still doing it.
I turn the bike on hit the run button fuel pump goes then the start button and nothing, indicator lights start flashing alternatively
Hmmmm, got a 2008 Fat Bob, just moving the bike without a good key fob close by causes similar issues. Double.check that your battery connections are clean and tight, also make should battery tender plug is covered if you have one and I would also go through the fob battery again , I have seen issues with fobs where the connections are not tight enough for the fob to send a good signal to the bike . Some batteries have no shelf life either .
