‘02 Legends install help
Helping my son install the Revo-Arc piggybacks on his ‘02 FXDL.
Per instructions we had to by some oem mounting hardware for a later model Dyna (‘08 and up). Primarily the upper shock stud.
All correct spacers and washers are in the correct location. The shock bodies are not perpendicular to the ground. They are kicked out at the top. Is this the way it is supposed to be ?
I’ve included a couple pics. Any input would be appreciated. The take offs were Drag Specialties and were not noticeably angled.
He has an email into Legends, but being the weekend, it may be a while before we get a response.
Thanks,
Dave
Have you tried it with the OEM studs..
Normally I would just start cutting spacers to fit, but I will just wait to see what the geniuses at Legend say, since we followed their directions to the “T” and these shocks ain’t cheap.
Thanks for the reply.
I am a Machinist, so I can easily modify anything that needs to be. Just using my “eyecrometer” cutting the hex off isnt going to be enough. It will cause rust though.
They did include a 1/2 bolt with the shocks, so we will try and make that work and machine the stainless spacers to get the shocks straight, which they say is a must.
I already knew what needed to be done, but for the price they charge for these shocks, I shouldn’t have to do anything but bolt them up.
If you are not a machinist or a magician, I would stay away from this company. Terrible instructions and customer service. The shocks are pretty though 😂
As in my pics, this is exactly how the directions
state they should be installed. Again, I can make any part needed. I just think Legends should have disclosed this info prior to a customer laying down that kind of money. I have to assume most consumers don’t have a machine shop in their garage.
And yes moving that 5/8 spacer to the outside seems like an option, but kind of defeats the purpose of buying the longer studs.
I have the same shocks on my '17 FXDB and love them! The only issue I had was interference at the lower shock bolt with my Thunderheader. I have the 14" shocks.
That is a good point ! In my service manual that is how it shows it. The bike is an hour away from me. I will look into that this weekend.
Even with the hex machined off , per legends email, it still wont be enough.
As mentioned in an above post moving the 5/8 spacer outboard is an idea, but don’t like all that extra stickout. This pic looks like the solution.
Thanks to all the suggestions from everyone.
On my '17, the hex portion of the stud rests inside the fender support. There is a matching hex recess that holds the stud from spinning when you tighten the nut under the seat. That's why your picture looked odd to me. I also got a picture of the depth/width of the fender support.
Edit: my bike is never this dirty, I got caught in some freezing rain earlier this afternoon.
