Throttle response problem
Old Oct 24, 2022 | 06:59 PM
Mattster's Avatar
Mattster
Default 2000 Super Glide throttle response problem
Hey all. It’s been a while since I’ve been on here and hope someone can help with an issue I can’t seem to figure out.
I got a 2000 fxdx with a 103 Stroker. I’ll start with my build and then what’s happening.
Thunderheader pipe
Fully rebuild tranny with jims updated shifter assembly
S&S super G
Primo oversized ring gear
Barnett clutch
New starter
103 inch motor
4 3/8 stroker
Flat top pistons
2012 heads with bigger valves
S&s 510 gear drive cams
Comp cam lifters
Dyno'd at 96 horsepower with 112 foot lbs torque
External oil cooler
New battery with tender
Compression releases
New screaming eagle ignition module
Msd coil
It fires up awesome and once warm idles nicely. If
you stab the throttle to rev it up quickly it chokes right out. Right to the point it’ll die. When your riding at low speeds it’s jerky, has lots decel pop at lower RPMs. At highway speeds, she hauls *** with no problems.
To try and fix the problem I’ve done intake seals, jetted the main to a 76, intermediate is a 31, replaced my petcock cause it had a slight leak, fuel is fresh, plugs and wires are new. I’ve double checked for a still possible intake leak and seems fine.
Any ideas wtf else it could be?
Thanks for any help 🍻
Old Oct 25, 2022 | 08:35 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Look in the S&S setup instructions that came with the carb. Jetting guide, 96" and up, mixture screw 1 - 1 1/2 turns, intermediate .032 - .036, main .074 - .088. Your intermediate jet is too small and running lean. Also check the accelerator pump shot, which may not shooting enough fuel at low rpm. With the engine at operating temperature, open up the pump adjustment 1/4 turn at a time. When ya blip the throttle and a puff of black comes out the pipes, turn it back 1/4 turn.
Old Oct 25, 2022 | 04:09 PM
Mattster's Avatar
Mattster
Thanks for the reply. I’ll change my intermediate jet to a bigger and try the settings you suggest. Cheers 🍻
Old Oct 25, 2022 | 06:29 PM
Mattster's Avatar
Mattster
Runs mint now with a 33 and a tune.
f1paul
Engine Mechanical Topics
15
Jun 3, 2022 04:13 PM
Remi_357
May 17, 2015 11:42 AM
EVOrider
EVO
Sep 25, 2013 05:27 AM
ShadoHawg
Mar 9, 2013 07:54 PM
masterblaster
Oct 4, 2010 03:22 PM
