Jack Stand
for my 2011 Dyna FXDF
I purchased an old rusty Sears Motorcycle jack
I saw this done on youtube but I made a few more mods. I cannot find the video.
I cut off the round pipe at the top that joins the two channels.
I removed the rubber off both top channel plates. I mounted 1X2 wood on the outside edges of the channel.
The flat plate across the front, kept the jack from going deeper under the bike, so I cut it off and moved it back (I would have to measure how far back)
I unbolted both top channels, got longer grade 8 bolts and washers for spacers and bolted the channels to the outside to increase width of the jacking plates.
by spreading the top plates and using the 1X2 wooden slats, no Adapter Kit is needed.
It will only fit under the frame by straightening the bike off jiffy stand.
It worked great till my jack started leaking. Somewhere on the bottom. I bought a $20 bottle jack at HF and jerryrigged it on. It works but it lacks height the previous jack had.
I can snap a pic of it. Recently, a buddy was cleaning his garage and realized he had a motorcycle jack he no longer needed. He gave it to me and its a Sears in much better condition. I need to swap and modifiy this one or just change out the jack.
this image, I copied of the net with my edits
Yes, it moved the stress points to the bolt holes on the red arms underneath. I have been watching, no issues seen. I have been using it for about 2 years on and off for projects.
How to modify jack for dynas
https://jsjacks.com/
