Check engine light code 16 fix?
Old Jun 7, 2024 | 07:41 PM
rasmukri's Avatar
rasmukri
Default Check engine light code 16 fix?
2001 FXDX with a carburetor
I got a check engine light that comes on intermittent and then goes away I did the jumper wire and put it in diag mode and it spit out error 16. Uhhhh how do I fix that?
Old Jun 8, 2024 | 08:40 AM
Max Headflow's Avatar
Max Headflow
Tighten battery terminals . If that don't work replace regulator..
Old Jun 8, 2024 | 02:20 PM
rasmukri's Avatar
rasmukri
Today I took out the battery and all the cables, also took off the ground strap to the starter and the POS lead as well. I cleaned everything with a wire brush and everything is good and tight. Tomorrow I'm going for a 2hr ride so we'll see if any check engine lights come on.
I also installed a volt meter on the handlebar so if the check engine light does do it's random turning on I'll be able to see the volts spike or drop.
PatoConcha
Harley-Davidson Street
Oct 11, 2022 03:04 PM
Kyle C Kirk
Nov 9, 2015 02:13 PM
chizman
May 15, 2011 04:35 PM
tekeum
Jul 14, 2010 08:55 PM
gatorwalt
Jul 24, 2008 10:26 AM
