valve stems ?
Old Sep 2, 2007 | 04:38 PM
07bobber's Avatar
07bobber
Default valve stems ?
ok i wanted to check the pressure and maybe add some air to the tires but it wont let me. i noticed some rubber type insert in the stems is it okay to remove them or is that apart of the rubber tubing inside the tire? thanks guys
Old Sep 2, 2007 | 05:16 PM
mud's Avatar
mud
Default RE: valve stems ?
What are you talkin about??
Got a picture??
mud
ORIGINAL: 07bobber
Old Sep 2, 2007 | 05:35 PM
07bobber's Avatar
07bobber
ok the pics wont come out clear enough to see but now thati rotated the tire, it kind of looks like a rubber o ring or somethin.
Old Sep 2, 2007 | 05:44 PM
Shovelhead Bob's Avatar
Shovelhead Bob
You got them "Fancy" type hex'd caps, doncha???????
Take that o-ring, and put it back in the cap, at the top....
It is just a seal, and sometimes sticks to the valve stem....
Old Sep 2, 2007 | 06:50 PM
07bobber's Avatar
07bobber
actually i have some black dice on the valves. good thinking thanks shovelhead. ill check it right now
Old Sep 2, 2007 | 07:09 PM
07bobber's Avatar
07bobber
well shovelhead you were right thanks again
Old Sep 2, 2007 | 09:30 PM
mud's Avatar
mud
ORIGINAL: 07bobber
thanks guys
bobber, I didn't think you could screw em in hard enough
to press the o-ring into the valve stem cavity.
Or I woulda mentioned that in the first place.
I guess with the added leverage of the black dice,
it is possible.
I have o-rings in my stem covers as well.
I put a little spit in there before I screw them on.
Doesn't need much to keep them on.
The rubber cushion is like a lock.
Check your tire pressure often.
And, at the very least, have a glance at
the rubber condition and tread depth.
mud
Old Sep 2, 2007 | 10:58 PM
07bobber's Avatar
07bobber
yeah i was thinking the tire looked low a few days ago and hell once i got the o ring out i checked the pressure and i had 15 lbs of air in there!!!![:@]so i filled it up to 38 lbs thats good enough for me
Petiej
Apr 25, 2019 07:03 AM
JeepMaker
Jul 16, 2013 04:26 PM
scottystreetbob
Jun 3, 2013 01:39 AM
t059736
Apr 28, 2011 02:06 PM
gregm
Oct 15, 2007 09:33 PM
