Dyna Springer Project
Old Jun 18, 2025 | 08:36 PM
bulldog1776's Avatar
bulldog1776
Default Dyna Springer Project
I'm looking into putting a springer front end on a 2007 Super Glide. My plan is to use a 23 inch front wheel, no fender.
I'm trying to decide between 2 over or 4 over on the springer. if anyone has pics of 2 over vs 4 over even on other models, that would be great.
Thanks guys.
Old Jun 19, 2025 | 07:57 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Sounds cool, make sure to post some pics.
Old Jun 19, 2025 | 12:20 PM
bulldog1776
Thanks.
Still trying to figure out the 2 over vs 4 over. Which will look better with the big wheel.
I'm kinda thinking 2 over will give it a little longer look without looking out of place.
Old Jun 19, 2025 | 12:36 PM
Reindeer's Avatar
Reindeer
Don't have any experience with a springer, but I've ran both 2 over and 4 over front ends on previous versions of my bike. The 2 over wasn't much different from stock as far as handling, but the 4 over was definitely a bit twitchy at low speeds and parking lots. Perfectly fine once up to speed though.
Old Jun 19, 2025 | 12:39 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
The modern springer was on a Softail I believe 31 inches.
on graph paper you should be able to draw out the rake and trail of the two head angles vs wheels size
Old Jun 19, 2025 | 07:36 PM
bulldog1776
Thanks guys. Will a 2 Over springer make the bike look like it sits up a lot higher in the front end, or will it just look more like 2 inches stretched out? I'm looking for as much of a long and low look as I can get.
Old Jun 19, 2025 | 07:48 PM
Tommy C's Avatar
Tommy C
How it rides is more important than how it looks.
Old Jun 19, 2025 | 07:54 PM
bulldog1776
Ride quality is not really a concern of mine, as far as if the suspension is a little rough riding.
Old Jun 19, 2025 | 08:42 PM
bulldog1776
After doing a bit more reading, I think a 2 over and a 23 inch wheel is going to set it up too high in the front. So, i could go with stock length. Or they make a 3 under, but I'm not sure if that would be too low for a 23 inch wheel to work?
I'm just trying to learn this stuff.
Old Jun 20, 2025 | 03:50 AM
98hotrodfatboy's Avatar
98hotrodfatboy
@" over plus a 23" tire will actually put it in the area of 4" over.. Stock is a 19".. Never seen a Dyna with a 23... They look great on a bigger Bagger but not so sure about a Dyna..
