Engine CLEANING
Old Jan 10, 2026 | 12:56 PM
MesquiteFLD's Avatar
MesquiteFLD
S100 is my vote.
Old Jan 10, 2026 | 01:20 PM
Mike1956G's Avatar
Mike1956G
I consider all that chemical stuff to be pure nonsense, only good for manufacturers who make a killing off it.
Mike
White spirit, a little oil, a few cotton rags, that's all you need.
Mike
Old Jan 10, 2026 | 01:37 PM
IdahoHacker's Avatar
IdahoHacker
[QUOTE=Mike1956G;22194588]I consider all that chemical stuff to be pure nonsense, only good for manufacturers who make a killing off it.
Mike
White spirit, a little oil, a few cotton rags, that's all you need...]/QUOTE]
White spirit and oil ARE chemical stuff.
Old Jan 10, 2026 | 04:51 PM
BMyers's Avatar
BMyers
Originally Posted by snake_eyes
Really? That works? No grease, just road grime.
road grime, bugs, grease. Spray it on, wait a bit, soft scrub brush and rinse
Old Jan 10, 2026 | 05:33 PM
dennyo's Avatar
dennyo
I don't spray the whole motor tranny down with Simple Green .
I spray it on a rag and wipe where the Oily is....
Old Jan 10, 2026 | 06:21 PM
02fx's Avatar
02fx
Be careful what you put on aluminum. S100 has always worked for me. Go over to the detailing section in this forum they can tell you how to clean and polish anything on a motorcycle and what to use.
Old Jan 11, 2026 | 04:44 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Thanks for all the tips, good info there. The issue with the engine right now is last spring when I took the bike to FuelMoto for the tune/break-in I made the mistake of renting an open trailer and it rained all the way/6 hours. Your guys are saying, rain no big deal, right? Well, this is Minnesota and Wisconsin rain, and the temp was just above freezing the whole 6 hours which means the roads were drenched in chemicals and now so are those cases. It's been washed since that day of course, but that trip really made the engine look like ****. I want to get it cleaned while it's on the lift because I'm too fvcking broken to be squatting in the driveway in the spring. I think I could get away with carwash in a bucket and a couple of stiff brushes, then using a spray bottle of water to rinse. That should keep the water at least controllable. Like @IdahoHacker suggested, I'm going to start out with carwash then move up if needed. I mean, I have until April/May before it's warm enough to ride so I have time and need the project.
Get yourself one of these to rinse with.
Old Jan 11, 2026 | 10:20 AM
touchdown's Avatar
touchdown
Chemicals work. I don't even remember the lite 60's and early 70's because of chemicals and I'm clean.
Old Jan 11, 2026 | 11:03 AM
MesquiteFLD
LOL
Old Jan 11, 2026 | 11:09 AM
IdahoHacker
I actually use a pump sprayer. However, I use it to spray on the soap/cleaning solution. Works great! Unfortunately, in my experience, it is utterly useless for rinsing, because it doesn't have enough pressure or volume of flow to do an adequate job of rinsing off the soap solution and loosened debris.
