Hayden M6 quality control has gone downhill
Old Feb 18, 2026 | 02:28 PM
  #41
OakMountainRider's Avatar
OakMountainRider
Another driver inflicted issue is if you do hard engine braking before the engine/primary is up to temperature. Then the cold chain slack is taken up by the auto tensioner.
Yep, It may be a good idea to open the primary cover now and then and have a look at the chain.
Old Feb 18, 2026 | 02:36 PM
  #42
OakMountainRider
The 2006 Dyna had a known issue with IPB failures, it was caused by improper alignment of the transmission case to the inner primary cover, for some reason there were no dowel pins to align these two parts properly.
The fix was a new transmission case and inner primary cover.
Yep, but not an easy fix. Also, probably not the only reason.
Old Feb 18, 2026 | 02:39 PM
  #43
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Schex
Drive belt to tight.
Hatband too tight...
Old Mar 13, 2026 | 01:44 PM
  #44
GROOVY1975's Avatar
GROOVY1975
I am not the type of guy to say something bad about company, unless it was needed to help others, that was why I posted this. I did so, for safety and to warn others of their quality control, just to be forewarned. That being said, with the weather improving, I have had a chance to get a few good rides in, and 1,000sh miles on the new tensioner and springs (new kit). It is GREAT, my primary chain sounds flawless now, and no more tinkling against my primary at idle, no more weird noises from the primary. It runs perfectly now, and I just inspected it at around 1K(sh) miles and it looks perfect! The tension is spot on, the shoe looks perfect, and shifting is nice and smooth (I also changed the primary oil of course) so it's all good now!
I don't like saying something bad but then disappear if the results turn out wonderfully! I had to update and tell everyone that it works and runs great (once I fixed the fitment issues).. I am very happy with the tensioner again, I just hope it stays this good for a while!
Old Mar 14, 2026 | 12:03 PM
  #45
Krazy8s's Avatar
Krazy8s
Originally Posted by Rounders
That doesn't seem like many miles. Did you inspect and see wear or did it fail?
Had the primary open to replace my compensator and noticed the outside front bottom corner of the shoe was broken off, and a piece on the inside bottom side had cracked off.
Top of the shoe had a little wear on it but had many more miles left in it. Dunno if the rest of the shoe would have fallen apart but i swapped it out anyhoo.
Boost
Mar 10, 2026 03:56 PM
Sparkules
Milwaukee Eight (M8)
Jun 5, 2021 08:19 AM
t150vej
EVO
Jan 29, 2010 12:49 PM
intempestivus
Apr 21, 2008 06:22 PM
GamblerSCS
16
Jan 20, 2008 04:24 PM
