Dyna Switchback Exhaust
Old May 8, 2026 | 01:12 PM
CesarVH's Avatar
CesarVH
1st Gear
Default Dyna Switchback Exhaust
Hello, i recently bought a Dyna Switchback 2014, and im triying to find some exhaust 2 on 2 long shots or fish tails, but i cant find any options, do you have a compatibility options that i could try?, or any options?
Old May 9, 2026 | 06:16 AM
Bubba Zanetti's Avatar
Bubba Zanetti
You looking for slip ons or a full exhaust system?
Old May 9, 2026 | 11:36 AM
CesarVH's Avatar
CesarVH
1st Gear
full exhaust, thanks for asking
Old May 9, 2026 | 04:36 PM
NORTY FLATZ's Avatar
NORTY FLATZ
If you go "full" then you'll need to accommodate the O2 sensors.
Vance & Hines Monster Duals, with fishtail tips.
Hope ur sitting down for the price...
https://cdn.shopify.com/s/files/1/06...derSystem3.jpg
Old May 9, 2026 | 10:33 PM
CesarVH's Avatar
CesarVH
1st Gear
well those arent for sale anymore, and for fish tail tips the pipes are big diameter, but thanks for answering
Old May 10, 2026 | 10:23 AM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
It’s going to be hard finding new exhaust for this bike, it’s been out of production 10 years already.
you can make any Dyna exhaust fit, the limitations are the mounting points ( you need to fabricate) and the saddlebags ( rear pipe to high to clear),
Old May 10, 2026 | 04:50 PM
CesarVH's Avatar
CesarVH
1st Gear
Do you know if all 103 dyna models have the same output of the exaust? (same size?) so if i buy a set for dyna, i just have to to the work on o2 sensors and mounts? if you have any reference that i can use would be awesome
Old May 10, 2026 | 05:09 PM
Paintslinger16
I don’t believe they moved the sensors around to much, it’s mostly mounting points and interference with the saddlebags, if you don’t plan on keeping the bags it’s going to open up a lot more options.
again finding new it’s hard for that model specifically and Dynas have not been made in eight years
Old May 10, 2026 | 06:48 PM
Tommy C's Avatar
Tommy C
Having a heavy, long exhaust on a Dyna with a rubber mounted engine will break brackets, transmission case ears, and increase the harmonic vibrations that the rider feels. Stick to the staggered dual exhaust with the crossover as it is a better performer as well with a good set of slip-on mufflers.
Old May 19, 2026 | 08:24 AM
pgrchaplain's Avatar
pgrchaplain
Not all Dyna Exhaust will work, they hit the Floorboards.
