Need Help
Old Sep 14, 2007 | 09:02 PM
dsb189's Avatar
dsb189
Default Need Help
I finally got around to changing all of the fluids in my 02 WG. Everything went great until time to take off the derby cover. I stripped the head on one of the bolts. I have already tried using an extractor, but it broke off in the bolt. I have the other four bolts out, but I need help in removing the last one. Any suggestions would be appreciated.
Old Sep 14, 2007 | 09:16 PM
tdegroot's Avatar
tdegroot
Default RE: Need Help
If you have access to a small hand grinder (dremel tool), you could use a small cut off wheel and grind a slot into the broken bolt large enough for a large flat bladescrew driver bit. The cut off wheel will also grind into any part of the extractor thats stuck.You could then attempt to back it out witha screw driver or even hit it with an impact tool with a screw driver bit attached. You will probably need a new derby cover once resorting to this, because it probably won't be possible not to damage it after resorting to this method. I hate when stuff like this happens.
Old Sep 14, 2007 | 10:27 PM
itileman's Avatar
itileman
I have had some occasional luck drilling into the bolt a ways until the bit gets stuck and then reversing the drill. Bad news is that sometimes the bit breaks off too. I'm thinking that the bolt is an alloy material as opposed to stainless steel, so you might have some luck. Also, once the hole is drilled, you might be able to get the extractor bit to grab. Good luck.
Old Sep 14, 2007 | 11:12 PM
Visionquest's Avatar
Visionquest
After you try grinding it as mentioned, if it still isn't out, try using a left hand drill bit, they work very well for extracting broken bolts/screws. You will have to use a cobalt bit and go pretty slow to have any chance of cutting that easy-out.
Old Sep 14, 2007 | 11:20 PM
grizzly's Avatar
grizzly
left hand drill bit.....hmmm, never thought of that...
Old Sep 15, 2007 | 05:43 AM
lilrooster76's Avatar
lilrooster76
Hey has anyone tried this thing out for stripped bolts?
http://www.4grabit.com/Default.asp?bhcp=1
Old Sep 15, 2007 | 06:17 AM
Blade68's Avatar
Blade68
ORIGINAL: lilrooster76
Haven't tried it but it looks like a good piece of equipment to have.
Old Sep 15, 2007 | 07:07 AM
skullguy's Avatar
skullguy
Derby cover screws are 1/4" in size. Take a 1/4" drill bit, make sure it's sharp, and slowly drill off the head of the screw. Once the head falls off, and the derby cover is removed, simply remove the remaining stud. If your careful, you won't even touch the derby cover.I think we all had this problem once. Itrashedthe remaining torx screws and bought stainless steel socket head cap screws. Not only are they easier to remove, they match the remaining screws on the primary cover.
Good Luck
Old Sep 15, 2007 | 03:15 PM
up in minot's Avatar
up in minot
YES!!! I have used that "Grab It", and it works f&*%ing AMAZING!!! Believe me,I've seenA LOT of stuck screws too. Works better than any easy out tool I've ever seen/used...
-Olkie
Old Sep 15, 2007 | 05:47 PM
dsb189's Avatar
dsb189
Thanks for ideas. Tdegroot, I was able to make a slot with thegrinder and used a flat head screwdriver to get the bolt out. Took about 1 minute.Skullguy, I already trashed therest of the bolts andjust picked up thenew bolts to match the rest of the primary. Thanks again for the help.
DaddyKnuck
Apr 27, 2017 07:30 PM
murd
Dec 9, 2013 09:58 PM
asparks25
Dec 20, 2010 02:09 PM
Low_Wider
Oct 31, 2008 02:46 PM
XL Junkie
May 14, 2007 09:40 PM
