Bullet Headlight
Old Oct 13, 2007 | 03:12 PM
brownie9xi's Avatar
brownie9xi
Default Bullet Headlight
For those of you that installed the HD bullet headlight, is it necessary to remove the fuel tank to connect the new headlight?
Old Oct 13, 2007 | 03:19 PM
Black Bart's Avatar
Black Bart
Default RE: Bullet Headlight
Brownie,
No, I did not have to remove my tank, but I had previously installed a 2" tank lift to it. So, that gave me more room to get up underneath and intothe frame to access the wires for the headlight.
Bart
[IMG]local://upfiles/16365/32593D1046AE4F02B45427F47F6E9DD3.jpg[/IMG]
[IMG]local://upfiles/16365/E0039A0CCBB2457FA55A41C266277C6C.jpg[/IMG]
[IMG]local://upfiles/16365/22E6B757E1544553B81CB649586E422F.jpg[/IMG]
Old Oct 13, 2007 | 03:26 PM
brownie9xi's Avatar
brownie9xi
Thanks Bart. I also have the 2" lift. Just got the headlight and wasn't looking forward to draining and removing the tank per the instructions.
Brownie
Old Oct 13, 2007 | 03:32 PM
Black Bart's Avatar
Black Bart
Brownie,
Good luck on the install. If you got the HD model be aware that yo may have to reverse the leads. When I installed mine the high and low beams were reversed. Justa heads up to you.
Bart
[IMG]local://upfiles/16365/D54EA9F138B249ACA367598E6ABBCF70.jpg[/IMG]
[IMG]local://upfiles/16365/AF8111E9B0A2475C8996AEE7643771FE.jpg[/IMG]
[IMG]local://upfiles/16365/A5B40F1FB7694A98807937BDB2FD6730.jpg[/IMG]
Old Oct 13, 2007 | 04:45 PM
brownie9xi's Avatar
brownie9xi
Bart,
Just finished hooking up the new light and sure enough, high is low and low is high. Did you just switch the wires in the connector?
Thanks for your help,
Brownie
Old Oct 13, 2007 | 10:05 PM
Splatter's Avatar
Splatter
Yeah, just reverse the wires. It's kind of a head-slapper when I did it because I realized the color coding of the wires would have tipped me off that it was going to happen if I didn't just put blind faith in the connector plug. [:@]
X90
Feb 20, 2016 08:33 PM
thanson_mopar
Mar 24, 2013 01:25 PM
RicMF
Jul 20, 2012 10:26 AM
motorcycle mikey
Electrical/Lighting/Alarm
Jul 31, 2009 03:09 PM
anubisss
Oct 9, 2007 06:41 PM
