need help
Old Nov 2, 2007 | 08:38 PM
Fred H's Avatar
Fred H
6th Gear
Default need help
I have an 07 super glide with the stage 1 download,screaming eagle pipes and the air filter.This evening I put a K&N air filter and all of a sudden the bike pops and misses on accecleration.Can any body help?
Old Nov 2, 2007 | 09:13 PM
dynarider's Avatar
dynarider
Default RE: need help
What happens if you go back to the SE AC? Does the bike run like it used to? Could be something's just not installed right or the breather tubes could be crimped maybe or filter not on right?
Old Nov 2, 2007 | 09:20 PM
DougsDyna's Avatar
DougsDyna
Might check your new filter installation, sounds like it might be leaking.
Old Nov 2, 2007 | 09:23 PM
JakeInMa's Avatar
JakeInMa
Recheck the map?
Old Nov 2, 2007 | 10:55 PM
voyager1's Avatar
voyager1
Once the MAP is set. I do not think it could just change on it's own.. It is like updating the bios on a home computer .
Old Nov 3, 2007 | 06:39 AM
ShoreRider's Avatar
ShoreRider
Sounds as though you need a remap for the new A/C. My guess it you've changed the flow sufficiently enough to affect you current ECM map.
Old Nov 3, 2007 | 01:11 PM
Fred H's Avatar
Fred H
6th Gear
Well I went to the dealer(under warranty)and they found a throttle body gasket leak.Thank you for your idea's,Fred
Rick Osgood
Feb 9, 2016 12:43 PM
TXRdKing96
General Topics/Tech Tips
Jan 16, 2013 07:12 AM
tbell1961
Nov 29, 2011 09:32 PM
snakeyes
Oct 22, 2009 09:14 PM
Larryc5079
Exhaust System Topics
Aug 12, 2008 08:00 AM
