sert data cable question
Old Jan 6, 2008 | 04:11 PM
rambobob's Avatar
rambobob
Default sert data cable question
I purchased the SERT and air intake for x-mas. Cables were not in stock. The manuel said the bike has a 4 pin plug. I looked at the bike today and it looks like a three pin plug with the fourth missing. Quetion ? Is this correct or my plug is missing a pin?
Thanks for the help.
Old Jan 6, 2008 | 05:22 PM
Wecroft's Avatar
Wecroft
Default RE: sert data cable question
You can't have it both ways. If the plug has four pin holes, it's a four pin plug no matter how many wire pins are in it.
Old Jan 6, 2008 | 06:19 PM
rambobob's Avatar
rambobob
I am going to dealer tomorrow for the wires. The manuel said the bikes data port is a four pin. I looked at the connection today
on the bike. It has 3 pins but one looks like it is missing. The manuel sas its suppose to be a 4 pin male port. I was worried that maybe one was broken off. First time I have looked at it since bought the bike. 07 SB
I also will have to get an adapter for my lap top bcause it is a 15 pin and the interface moduler is a 9.
Old Jan 6, 2008 | 08:28 PM
rewog's Avatar
rewog
That 15 pin is a VGA out. You need to also purchase a Belkin "USB to serial" adapter.
Old Jan 6, 2008 | 08:29 PM
johnfxdb's Avatar
johnfxdb
3 out of 4 ain't bad.... There is nothing wrong with yourbike or SERT cables. That is the same as mine.
Old Jan 7, 2008 | 01:04 AM
Dynaflyer's Avatar
Dynaflyer
Rambobob, Just last evening I used the SERT to program the ECM. Do yourself a BIG favor and avoid the The hassle I went through.
Get a BELKIN, USB to Serial Cable and use windows XP. Thanks to HD and or Microsoft windows Vista WILL NOT Work!
I went to office Depot and purchased the Belkin. Circuit city and Best Buy did not carry belkin USB to serial connector.
The Cable number I got was F5U409-CU . Fry's electronics is another place to try.
If it doesn't connect try switching com ports on the SE Tuning menu. You can email me for any issues and I can call you if you need any help.
Old Jan 7, 2008 | 01:31 AM
Dynaflyer's Avatar
Dynaflyer
rambobob, Check out this thread for a little more info on the SERT.
https://www.hdforums.com/m_2675672/tm.htm
BTW, In the SERT user's manual under "TroubleShooting" It states to use a Belkin cable. Go Figure!
Old Jan 7, 2008 | 05:30 PM
rambobob's Avatar
rambobob
Thanks for the help. Dealer said the pins on bike used to be four now its three, makes no difference. Did buy a adapter and it did not work. Went and got the Belkin and it worked first time. Also installed air intake. Cant wait to ride.
Old Jan 8, 2008 | 12:07 AM
Dynaflyer's Avatar
Dynaflyer
Awesome! Glad it worked ! enjoy your first new ride with the New map. I really notice a difference after the remap.
Isn't this forum great!
Old Jan 8, 2008 | 08:21 AM
Whiffleboy's Avatar
Whiffleboy
I just loaded my first last night. Can't wait to go to work today! (did I just say that??)
Dyna, what map did you use? I used a canned one first and will try one of Mud/JamieWG's next.
Whiff
