Second oil change... when?
Old Feb 8, 2008 | 09:58 PM
Topspin's Avatar
Topspin
Default Second oil change... when?
I had the bike serviced at 1000 mi as recommended.
The second scheduled service is at 5000 miles.
Did you guys wait for 5K or do it earlier than recommended? I do about 5-6K miles a year (this isa pleasure not commuter bike).
Old Feb 8, 2008 | 10:02 PM
Cornhusker's Avatar
Cornhusker
Default RE: Second oil change... when?
I run synthetic oil and change oil/filter every 3k miles. Everyone has their own ideas on oil change frequency.
Old Feb 8, 2008 | 10:30 PM
DougsDyna's Avatar
DougsDyna
I did my second oil change after the first oil change, but before the third oil change,thought that made sense
Hd did my first, andput Syn3 in at about 1200 miles. Took the Syn3 crap out at 2500. I run M1 20W50 and change oil every 2500-5000.
I do check the stick before most every ride. If the level shows consumption, I change it.
DougJ
Old Feb 8, 2008 | 10:37 PM
07bobber's Avatar
07bobber
im baD.... i did my first at 5000 and my next change willbe at 10000
Old Feb 8, 2008 | 11:41 PM
Arizona Flash's Avatar
Arizona Flash
Every 2,500 miles on the engine, every 5,000 for the other two holes.
Old Feb 9, 2008 | 06:56 AM
Sir Ed's Avatar
Sir Ed
all changes after the 1K did myself... at 1250 orso got rid of the Syn3 and shifted to Mobil One V-Twin, a 100% Syn oil in primary and engine... put Redline Heavy Syn Gear Oil (75W250) in tranny and what a difference that made, at 5K pulled all oil plugs and they were finally clean of silvery residue... plan now is engine every 3K, Primary and Tranny every 10K.. Ed VaBch,Va
[IMG]local://upfiles/44748/436525DD481947AC950C8A913C7648B7.jpg[/IMG]
Old Feb 9, 2008 | 07:53 AM
XMA's Avatar
XMA
Engine oil every 2,500. Tranny & Primary every 5,000
Old Feb 9, 2008 | 08:01 AM
jnogreen's Avatar
jnogreen
what he said........ Change it Daily if you can afford it.......
Old Feb 9, 2008 | 08:04 AM
RAWHIDE07's Avatar
RAWHIDE07
If you ride 5-6 thousand miles per year you still need to change the engine oil and filter at least twice yearly.The trans and primary once per year.More miles, adjust accordingly.
Old Feb 9, 2008 | 08:23 AM
rounder's Avatar
rounder
5014 miles ....getting it done today
I second that you should change oil sooner if you are doing only 5K per year....Also Florida is considered an extreme condition state. I know for my car the owners manual recommends to change the oil every 3500 miles instead of the usual 7000 mile intervals for other seasonal states(according to owners manual).... Don't know if Harleys should be the same way though.
