Outer primery
Old Feb 12, 2008 | 08:27 AM
Frozen Crome's Avatar
Frozen Crome
Default Outer primery
Looking for and outer primery cover for my 2008 FXDC with no hole any suggestione besides EBAY? I may have to look in the soft tail section were people changed out for the belt drive any suggestions?
Old Feb 12, 2008 | 09:14 AM
jmpancoast's Avatar
jmpancoast
Default RE: Outer primery
ORIGINAL: Frozen Crome
A Wide Glide outer primary will work and does not have the hole since they do not come with mid controls. If you use the WG primary, you will want to work out a plug for the shifter shaft hole in your inner primary.
Old Feb 12, 2008 | 04:57 PM
Frozen Crome
That is great it gives me more options I wasn't sure, as far as the plug goes and corect me if I am wrong it should be in the HD Forward control kit. Also does any one know the year span that matches up with the 08?
Old Feb 12, 2008 | 05:14 PM
jmpancoast's Avatar
jmpancoast
06 - 08 kits fit the same models. Earlier model kits can be used as well. The plug which comes in the forward control kit is for the hole in the outer primary which is left behind when the shifter shaft from the mids is removed. If you use a Wide Glide outer primary on a bike which had mids, you inner primary will still have a hole. This is the hole I am speaking of needing to be plugged. The cosmetic plug which comes with the forwards is not the type of plug I would recommend using. Something such as a rubber expandable freeze plug would be better suited for this.
I hope I am explaining this adequately.
Old Feb 12, 2008 | 05:27 PM
Frozen Crome
Yepgot it and thanks for the info I know exactly what you mean. I am glad I asked I assumed it was in the kit.
Old Feb 12, 2008 | 05:37 PM
jmpancoast's Avatar
jmpancoast
On the models with mids, the shifter shaft hole on the outer primary has a hollow neck which protrudes towards the inner primary. The inner primary has a hollow neck which meets the one from the outer. Together they seal allowing the shifter shafter a dry well to sit in.
The Wide Glide Outer doesn't have this neck since it doesn't have the hole for the shifter shafter. Using the WG outer on a mid inner, there is nothing to seal that neck, therefore it will leak primary fluids.
Old Feb 13, 2008 | 09:27 AM
StevenT1967's Avatar
StevenT1967
Frozen Chrome,
Watcha gonna do with your stock chrome outer primary cover? It would sure look perty on my FXD. Let me know if you are interested in selling it!
Steven
Old Feb 13, 2008 | 11:38 AM
Frozen Crome
I will probally sell it once I get the right stuff for mine just need to find maby an inner and outer for mine. Unless it is possible to use a piece of all thread and run it through the tube and seal it with a nut and washer on both sides. any one have an opinion on the idea?
Old Feb 13, 2008 | 04:45 PM
Frozen Crome
Does any one have an outer primary and inner for sale or know were I could find one for a good price?
Old Feb 13, 2008 | 05:02 PM
wkdavistx's Avatar
wkdavistx
Do you really need to replace the entire primary cover or just the inspection plate?
