Progressive 412's
Old Feb 15, 2008 | 12:30 PM
trampsinger's Avatar
trampsinger
Default Progressive 412's
Is this the right part number for my 07 StreetBob? Aren't the stock 11.5" or 12"?
Thanks
412-4037C
Old Feb 15, 2008 | 01:09 PM
Chipstah's Avatar
Chipstah
Default RE: Progressive 412's
Stock are 12"
Old Feb 15, 2008 | 01:11 PM
JoeWV's Avatar
JoeWV
I just bought some 412's for my 07 Bob. The Progressive site says the stock size is 12", so thats what I went with. Eastern Performance has these at a really good price right now.
Old Feb 15, 2008 | 01:12 PM
07bobber's Avatar
07bobber
YUP STOCKERS ARE 12"
Old Feb 15, 2008 | 01:33 PM
Tony P's Avatar
Tony P
Would that besame for the Super Glide?
Old Feb 15, 2008 | 01:55 PM
mikedmeyer's Avatar
mikedmeyer
Super Glide stock shock is 12.5" so the 12.6" 412 is the closest. You could also put 12" or less on there and lower your seat height to where the Bob or LR are.
Old Feb 15, 2008 | 03:07 PM
trampsinger
I'm looking to lower. Is an inch to much or should I only go a half inch?
Any example out there?
Thanks
Old Feb 15, 2008 | 04:46 PM
Hughey79's Avatar
Hughey79
Since there is technical problems that are being worked out on the search problem. I am lookingat buying the progressive 412 in 11 inch for 05 dyna super glide. I am around 230 lbs and usually ride solo with the occasional rider. Will this be okay or will I have other issues. I am looking at ordering from eastern performance tonight pending the answers I get. Thank you in advance.
Old Feb 15, 2008 | 05:25 PM
Chipstah's Avatar
Chipstah
trampsinger - PM sent - I have 412 11" heavy duty, very stiff but great handling. Progressive recommends HD for 2 up or solo over 225 lbs. Yet I am only 185 and find the HDs to be great - love them, but can see why others might not want such a stiff ride. Also didn't want to have to worry about bottoming with the lower shocks. Also put Progressive springs in front and lowered to match the rear.
Hughey - see above note to trampsinger
Old Feb 15, 2008 | 07:27 PM
strich's Avatar
strich
Chip
I know you told me in another post and reiterated here that you've got the progressives. Are you aware of any blackened shocks (this is important) that aren't such a stiff ride? I've got a bad back and like the way the HD shocks ride. I also don't want to spend a fortune on them.
thanks bro
