throttle cable problem question
Old Feb 20, 2008 | 09:23 PM
VenturaChop's Avatar
VenturaChop
Default throttle cable problem question
whats up guys just installed some night train throttle cables and where they connect under the lower housing them seem kind of lose just wondering that is normal .. thanks guys
Old Feb 20, 2008 | 09:34 PM
up in minot's Avatar
up in minot
Default RE: throttle cable problem question
By "under the housing" do you mean the switch housing side; by your brake?
Old Feb 20, 2008 | 09:35 PM
wkdavistx's Avatar
wkdavistx
Do you mean loose as in wobble or loose as in swivel?
Old Feb 20, 2008 | 09:38 PM
up in minot
Yes, please elaborate . . .
Old Feb 20, 2008 | 10:20 PM
VenturaChop
yeah where the master cylinder i gave them a good tug and they didnt come out is there a chance they can come out???? they work great nice and quick when i turn it i think the move about a little more then 1/4 of an inch
Old Feb 20, 2008 | 10:31 PM
NOTORIOUS1's Avatar
NOTORIOUS1
mine are the same way man, they are in there solid though. i wouldnt worry about them coming out
Old Feb 21, 2008 | 02:26 AM
bikerdog134's Avatar
bikerdog134
good looking bike. how much did you lower it
Old Feb 21, 2008 | 05:56 PM
TurkeyRun's Avatar
TurkeyRun
I just put Street Bob cables on my FXDC. They flop around side to side, but don't come out unless I yank on'em real good. If you did the cable swap yourself, you'll know if they're gonna fall out or not. Besides - with the cables adjusted, there is ... how to describe this..... "linear tension" between the end that sits behind the throttle plate, and the end that plugs into the handgrip. Does that make sense? Seems to me that if they were loose enough to fall out, you're throttle would already be non-functional
I don't wanna to stear ya wrong here, but if they are connected right in the throttle grip, are adjusted so the throttle works, I really don't see how they could just come out.
Old Feb 21, 2008 | 09:01 PM
up in minot
Yeah, mine do the same thing. No problems so far. If what you're talking about is what I think it is, then there are two little (by little I mean tiny) snap ring looking things that hold your cable into that switch housing. Most likely those are a little warped, or like others have said, your tension is a little loose. Nothing I would worry about too much though, personally. If you want, have it check out, for that piece of mind...
Old Feb 21, 2008 | 10:23 PM
VenturaChop
nah well it funtions bad *** it goes back like in a milasecond lol its super quick and have a bout a 1/8 to 1/4 in of slack in the grip if i give it a really good tug it will come out but i mean a really good tug
