bike will not start
Old Feb 24, 2008 | 10:28 PM
ggibson's Avatar
ggibson
Default bike will not start
Help !! , changed my throttle grip, all went well but after putting switch housing ect back together I turned on ignition then turned the start swith on but heard no fuel pump!!!, no blinkers either and when I switch off and remove key no alarm lights(blinkers) come on??? Could I have broken the wires in the housing that go to the switches?? I didnt think I would have put that much force on them, they are held in place by a little plate in the upper housing anyway, any thoughts??
Old Feb 24, 2008 | 10:50 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: bike will not start
Did you disconnect the battery before you worked near all that electrical wiring? You might have crossed a circuit and blown a fuse. Check your fuse box.
Old Feb 25, 2008 | 12:48 AM
ggibson's Avatar
ggibson
All fixed !!!, it was a fuse all along, as you said I should have disconnected the battery, even though there is no exposed wiring or exposed switch terminals obviously it can still short out. Thanks for your help KB.
Vintage1951
Oct 21, 2017 04:16 PM
SugsPa
Jun 2, 2017 08:21 AM
Robinator
Jun 7, 2015 06:54 PM
OriginOfEvil
May 14, 2013 11:03 AM
81fxb
Aug 6, 2008 05:16 PM
