Forward Controls
ORIGINAL: swellsmd
Did this back at Christmas. Be prepered to spend a full day on it. You will have to remove everything left side including the clutch and flywheel. There is a tool to lock the clutch and flywheel in place to loosen and tighten the bolts. I did not have this but cut a piece of wood similar in length and it seemed to work fine. Make sure you have the shop manual before you start this. I really had no idea until I got into just what all was involved. It wasn't hard, just took all day to do. They are great when its done!
swellsmd
swellsmd
You do not HAVE to remove the primary and there are links here to give you a few tips to keep the install clean.
I have a set of forwards coming and will be leaving the mid shaft in (I don't want to pull the primary apart).
Cheers
I bought my Fwd's from Zanotti's and saved $60.
They got here monday evening at 5:00
They were on before dinner.
No way in hellI would pay the Stealer $300+ to do it.
If you can change your spark plugs, you can do it.
Oh, I went with the OEM set, though the Kury's are nice too.
ORIGINAL: cHiLi_11
Not to high jack the thread, but what are your opinions on a forward controls on a first bike? I am debating if I should order them for my dyna that will arive next week.
Nick
Nick
a m8 put them on last week and got footpeg vibration from the brake arm moving side to side , we fixed it with a hand made thin rubber washer between the brake arm and the footpeg mount , looked like somthing was missing .
ORIGINAL: cHiLi_11
Nick
Nick
Not to ask an overly dumb question, but what the hell, it's never stopped me before. I have an engine guard on my 08 FXDC, has anyone had problems with using the forwards with an engine guard? I saw that Kuryakyn says that their forwards won't fit with an engine guard which is kind of a bummer since the Kury's are really sharp and appear to install much more easily than the H-D ones.
ORIGINAL: Royce
[IMG]local://upfiles/41150/4614C3E7A8BC49FB80BBF22BE585786B.jpg[/IMG]
[IMG]local://upfiles/41150/64076F44D9EE4B559FF61588203A1224.jpg[/IMG]
[IMG]local://upfiles/41150/E4D1CC1F7C424A09B9AA6CBF3CE2E7EA.jpg[/IMG]
Greg, thanks for the pictures and information. It looks like the issue may be a combination of where the forwards are installed and the clearance that you mentioned. The brake and shifter levers on the H-D forwards don't seem to be as wide as the Kury's. That may bethe issue. I've attached a couple of pictures of my bike. I'd appreciate your thoughts on them. Sorry the pics aren't clearer.
[IMG]local://upfiles/25161/23806F5F6DD5469AA0739099A53D42CF.jpg[/IMG]
[IMG]local://upfiles/25161/39392FCA8D8E41F690686FF7FFA1A2B2.jpg[/IMG]
