Adjustable Ride Height
Old Mar 19, 2008 | 03:34 PM
HimeHog's Avatar
HimeHog
Default Adjustable Ride Height
I've seen a lot of talk about new shocks and I've looked all over the internet and the only shocks I can find that you can adjust ride height on is the air shock systems (not just air shocks that you can adjust psi for your particular softness or firmness of ride.) Is that really it, do I have to fork out $1,000 to $1,500 to be able to adjust my ride height. I mean I wanna lower my bike but I also like ridding two up and I know it will scrape like crazy if I lower it like I want. Are there no coil over shocks like on all those jap tuner cars that you can adjust heighth on as well as pre load?
Old Mar 19, 2008 | 04:09 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: Adjustable Ride Height
The preload itself will change the ride hieght quite a bit from the lowest to the highest setting.My Progressive 412s change 3/4" in three clicks of adjustment.
Old Mar 19, 2008 | 04:13 PM
Chipstah's Avatar
Chipstah
ORIGINAL: SPECIAL ED
+1 -- That ought to be enough to go from solo to two-up if ya get 1" lower than stock to start with.
Old Mar 19, 2008 | 09:18 PM
SPECIAL ED's Avatar
SPECIAL ED
Chipstah, speaking of Progressive where's a good place to buy thier standard front spring kit on line? Some of the places I've looked only show the springs themselfs do they all come with the spacers?
crawrj
Oct 31, 2014 09:55 AM
chugger93
Jun 2, 2013 06:11 PM
Inthespiral
Jun 16, 2012 11:26 AM
quig
Mar 5, 2008 12:29 AM
dsuppa
Aug 29, 2006 08:07 PM
