help help help
Old Mar 30, 2008 | 09:24 PM
harley05custom's Avatar
harley05custom
Default help help help
i was working on my ape install today,and have a few questions.
how do i bleed the front brake?
how do i adjust the throttle cable?
It turned into more than i thought i can tell you that.
also to add a little more to this i also installed my forward controls,the are the h.d ones.
what adjustments will i need to do on these?
Please help
Old Mar 30, 2008 | 09:36 PM
pwer pla's Avatar
pwer pla
Default RE: help help help
EFI or Carb??
Old Mar 30, 2008 | 09:50 PM
harley05custom
opps its a 2005 sg custom efi
Old Mar 30, 2008 | 09:52 PM
DynaMoHum's Avatar
DynaMoHum
Ok
VenturaChop's Avatar
VenturaChop
you need to get a service manual man i dont know if my 07 is the same as your 05
Old Mar 30, 2008 | 09:55 PM
jayhantz7's Avatar
jayhantz7
ORIGINAL: VenturaChop
+1
The service manual is like a bible... it tells how to do everything, step by step
Old Mar 30, 2008 | 10:05 PM
pwer pla's Avatar
pwer pla
On throttle cable if i remember right you will see in the efi where you attached the cable there is a tab that moves up (i think) as you twist the throttle it will eventually hit a stop you adjust the throttle cable until it just touches the stop with the throttle fully twisted. then the idle cable is tightened until the spring it sets in seats in the notch that holds it in place. Sorry I don't know all the technical names for these parts. easy adjustment, take your time and you'll get it. i just finished a bunch of mods that I figured to be way over my head, but with time and patients got everything done and every time I ride my scoot the feeling of pride is much greater than before knowing that everything that has been done to the bike I did personally.
Old Mar 31, 2008 | 05:38 PM
JayFromPa's Avatar
JayFromPa
There are some good threads in the tech section on bleeding the brake. Gives you two methods of doing it.
Raccerx67
Exhaust System Topics
Feb 11, 2013 05:36 PM
BadX
Mean City Cycles
Jan 3, 2011 08:16 PM
karz10
Sep 16, 2008 07:19 AM
Jerm21
Aug 19, 2008 10:28 AM
