Need to replace battery!
Old Apr 9, 2008 | 07:17 PM
pinibo's Avatar
pinibo
6th Gear
Default Need to replace battery!
How do you replace a battery in 02 Dyna Low Rider? It is very tight in there.
Old Apr 9, 2008 | 07:35 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Default RE: Need to replace battery!
First take a 10mm wrench and put a 45 degree bend about an inch or so from the box end. Now, remove the two bolts that support the battery tray to the frame, get eyeball level to the battery, the bolts are to the left, bolts are different lengths don't mix them up, one bolt goes up into the frame. Position the tray down, disconnect the negative cable first. Upon installation connect negative cable last. When the tray is loose you can access the batt cables real easy and you will see why the bend in the wrench is there. Good luck.
Old Apr 9, 2008 | 07:39 PM
seniorsuperglideE8
Something else, while you are in there. Get yourself a battery tender jr. and put the pigtail on while you are hooking your cables.
Old Apr 9, 2008 | 07:52 PM
pinibo's Avatar
pinibo
6th Gear
Thanks!
Old Apr 9, 2008 | 11:13 PM
wideglidebob's Avatar
wideglidebob
also buy a service manual
Old Apr 11, 2008 | 07:10 AM
soup48's Avatar
soup48
I agree with senior on both. If you have a set of sockets use that instead.
wardjs
Jul 7, 2019 03:52 PM
tmitchellof PG
Jun 24, 2008 09:21 AM
SkeeterB767
Oct 31, 2007 06:10 PM
dlongo8241
Feb 6, 2006 10:27 PM
1sportytrike
Jan 9, 2006 10:53 AM
