OEM Forward Controls Installed
Old Feb 15, 2006 | 12:49 AM
wjcbsr's Avatar
wjcbsr
Default OEM Forward Controls Installed
So I decided to give the installation a try myself. I did plenty of reading (here and elsewhere). I even made myself a little primary drive locking tool for about $2. The Stealer wanted close to $70 CAD for the same tool with a HD logo on it.
The install was way more involved than I thought. Off comes the battery, starter, primary cover, primary case and all the existing shifter and rear brake linkages. I started the job last night and worked 4 hours. Tonight I finished her up in another 2 hours for a total of 6. The dealer wants 4 hours for about $500 CAD (just labor). The bottom line is if you have a little mechanical aptitude and take your time, you can do it too (insert disclaimer here).
Anyone who claims they can do the job in 30 minutes is either nuts or isn't doing it properly "by the book".
I would definitely recommend having the shop manual at your finger-tips.
Anyway, I thought I would share my experience with all of you in case you're thinking about tackling this job yourself.
And, as an added bonus, for the cost of shipping, I can make a few more primary drive lock tools for anyone who's interested. I've got enough material left for about 4 more. Just PM me. First come, first served
Bill.
P.S. Check out my web site at Linky
[IMG]local://upfiles/7228/4217AEDBE0C04C2387DC17617755F9EB.jpg[/IMG]
[IMG]local://upfiles/7228/CCC5CA13FDB34DC4A54ADEE29B247908.jpg[/IMG]
Old Feb 15, 2006 | 01:00 AM
BlackOak's Avatar
BlackOak
Default RE: OEM Forward Controls Installed
Congrats on a Job Well Done!!
betcha ya glad thats over with huh??
Old Feb 15, 2006 | 01:12 AM
phreak's Avatar
phreak
Got pix of your install?
Old Feb 15, 2006 | 07:10 PM
theyogawarrior's Avatar
theyogawarrior
sorta on the subject...anyone find any blacked out forward controls for the Streetbob? And what do you boys think about old school running boards for the BOB?
Old Feb 15, 2006 | 07:29 PM
phreak's Avatar
phreak
I don't believe Harley has any blackedout mounts phor the phorward controls. Only the chrome kits. You would have to have the levers and mounts powder coated somewhere. I think it would be worth it, but I haven't gotten around to it.
phootboards? I think it would look like duck pheet on a Dyna with phorward controls. Probably passable with mids.
Old Feb 15, 2006 | 10:26 PM
superdog48's Avatar
superdog48
I have installed the forward controls on my '04 in an hour, thats removing the mids and installing the forwards. On my '06 my brother and I changed the forwards from my '04 to the '06 and the thing I had to change was the shifter rod from the original to the '06 shifter rod.
Old Feb 15, 2006 | 11:33 PM
Gadgetech's Avatar
Gadgetech
I must be missing something. 4 hours to install forward controls? Removal of the "battery, starter, primary cover, primary case." A lot has changed from 05 to 06 for all that to be required. You were just putting on forward controls right? I am glad I didn't have all that to go through. I changed out the rear break linkage and installed the cap over the original shifter spline and that was about that plus a few other things, but I didn't have to remove ANY covers. Did you take out the original shifter spline?
Old Feb 16, 2006 | 08:11 AM
JonHanna's Avatar
JonHanna
and to thinksomeone on here said they can do it in 30 minutes! I don't think so! Job well done man.
Old Feb 16, 2006 | 08:25 AM
DGlide04's Avatar
DGlide04
ORIGINAL: Dynamite
You're right, anything up to the 2006 model year should take an hour or less. No primary to remove, all connections are external to the primary. Starting in 2006, the forward controls were rerouted and installation now includes having to remove the outer primary, not so easy anymore. Did the forwards on my '04 and it took no time at all. 2006 and up, much more involved.
Old Feb 16, 2006 | 07:43 PM
wjcbsr's Avatar
wjcbsr
Thanks for that DGlide!
I thought I was losing my mind or something...
The Bob is my first Harley so I had no idea what the install was like for anything prior.
