whine
Old Apr 22, 2008 | 05:26 PM
SM49's Avatar
SM49
Default whine
Has anyone had a whine,noticed when coasting to a stop,2001 FXDP with 11" rear shocks.
Old Apr 22, 2008 | 06:05 PM
jmpancoast's Avatar
jmpancoast
Default RE: whine
Any recent work or mods done by you or anyone else? Are the shocks a new add-on?
Old Apr 22, 2008 | 06:38 PM
Righteous's Avatar
Righteous
Default RE: whine
Check the tranny lube. It's probably gear noise.
Old Apr 22, 2008 | 06:47 PM
kk6pg's Avatar
kk6pg
Default RE: whine
My ex whines all the time
Old Apr 22, 2008 | 07:31 PM
hounddog's Avatar
hounddog
Default RE: whine
did you recently adjust the primary chain?? i;ve noticed that a few times ive miss judged the tight spot in the chain when i adjusted it and it was too tight which resulted in a whine and low speeds (ie. slowing down and at a stop idling) so if you had check that and fix it soon almost better to be loose than tight cuz it stresses the main shaft bearing in ways its not ment. there be me 2 cents hope it helps..
Old Apr 22, 2008 | 09:45 PM
SM49's Avatar
SM49
Default RE: whine
recently put on 11" shocks,lubes are ok.
Old Apr 22, 2008 | 10:37 PM
trip20's Avatar
trip20
Default RE: whine
ORIGINAL: SM49
Are you in first gear, with the clutch lever pulled in, coasting to a stop?
That whine is normal.
Old Apr 23, 2008 | 07:08 AM
jmpancoast's Avatar
jmpancoast
Default RE: whine
Putting shorter shocks on changes the angle of the swingarm. As a result, the tension on the drive belt also changes. This could be your whine. Check and adjust tension, if necessary.
Old Apr 23, 2008 | 07:13 AM
dyna07custom's Avatar
dyna07custom
Default RE: whine
ORIGINAL: Wyde Glyde Bry
ORIGINAL: SM49
yes what gear if your in first it will whine even with clutch in
Old Apr 23, 2008 | 08:46 PM
SM49's Avatar
SM49
Default RE: whine
it does it in neutral too.
