30 Tooth conversion
Old May 3, 2008 | 03:19 PM
damadman's Avatar
damadman
Default 30 Tooth conversion
I was wondering if anyone has changed there forward belt sprocket from a 32 to a 30 tooth?? and if they had to change the belt? If so what part # u use for the belt??
Old May 3, 2008 | 07:09 PM
jsbridgew's Avatar
jsbridgew
Default RE: 30 Tooth conversion
the part number is floating around here somewhere....do a search on "andrews power pulley" or even "gear ratio".... it's around here somewhere... i was going to do the same thing, but it's just so involved.... are you going to do it?
Old May 4, 2008 | 12:06 AM
SURFOR Chop's Avatar
SURFOR Chop
What's it do to your speedo/odometer? It should lower your gear ratio ... right? Therefore, you'd have to go faster according to your speedo to make the actual speed; and your odometer would show more miles than you actually traveled. Is that correct?
I've got a 5-speed andcommute, I think I'd rather go the other way ... make it overdrive by pulley.
R/
Priest
sven556
Dec 23, 2021 06:31 PM
joee
Jul 14, 2014 03:06 PM
twistedcherokee
Feb 10, 2013 12:09 AM
fastbagger
Jan 27, 2008 09:00 PM
rockerhead
Aug 23, 2007 02:12 PM
