Im baffled
Old Feb 28, 2006 | 10:25 PM
twsteddyna's Avatar
twsteddyna
Default Im baffled
So Im wondering how does one pull out the baffles on a 2006 Dyna Glide FXDI ?
Old Feb 28, 2006 | 10:31 PM
broke joker's Avatar
broke joker
Default RE: Im baffled
Don't waste your time. Just bye a new exhaust system or slip on's. But ya can't beat the sound of Samson exhaust. Just my 2 cents though.
Old Feb 28, 2006 | 10:42 PM
twsteddyna's Avatar
twsteddyna
Well Im looking for that no holds barred Harley grumbling roar when I hit the throttle ?
Old Feb 28, 2006 | 10:43 PM
tb2377's Avatar
tb2377
definatly don't remove the baffles. there a post ablout that in this forum somewhere. just get some slips ons or a complete exhast
[IMG]local://upfiles/7785/83EE577F46204A9C9A9952744BC0ED23.jpg[/IMG]
Old Feb 28, 2006 | 11:09 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You can still get the SEII slip ons or get a Vance & Hines exhaust but if you chenge the stock exhaust in most any way you have to reprogram the ECM with a download or SE Race Tuner. Better check with your dealer but don't pull the baffles out of the stock exhaust.
Old Mar 1, 2006 | 01:05 AM
fxdbi's Avatar
fxdbi
Since everyone is just dickin you around ill tell you. Just get a 2" hole saw and stick it in the end of the pipe and drill. You have to drill out the welds and they will pull right out. I did this to mine and did an air cleaner and pcIII. Just a temp fix untill i find the pipes i want.
Old Mar 1, 2006 | 01:54 AM
The Punisher's Avatar
The Punisher
[sm=badidea.gif]
Old Mar 1, 2006 | 06:25 AM
Reino's Avatar
Reino
https://www.hdforums.com/m_300638/tm.htm
Old Mar 1, 2006 | 10:14 PM
sonofthedesert's Avatar
sonofthedesert
I drilled mine out with a hole saw and installed some homade thundermonsters. If you are a bit handy you can do it to. I wouldn't just drill out the baffles alone as they tend to sound tinny. Mine sounds awesome now, especially when I nail it. The idle is still quiet enough to not **** off the neighbors in the morning. I've got more low end torque and a little more hp aswell.
Old Mar 2, 2006 | 03:13 AM
CraigC's Avatar
CraigC
ORIGINAL: broke joker
Just buy a new exhaust system or slip on's.
Easier said than done. Exhaust systems for the `06's are scarcer than chicken udders! Still waitin' on mine.
