+1 The parts listed are what's now on my '07 Bob.
ORIGINAL: dyna rider
The post was on 4/21/08. If you click on my name (dyna rider) and go to the last 100 posts, you will find the post on page 3. There you will find the pics as three attachments. It will show up as a console gasket assembly 197.00. The ignition switch is part #71313-96a and is 67.60. \\;\\\\\\;You should order all this from zanottimotor.com in Pa. which is much cheaper than your dealer. If you give them your key number they will order the ign. switch with the same key you have now and that way the ignition switch left in the neck becomes the fork lock \\;\\\\\\; and is the same key as the ignition switch on the dash.
I thought I posted the part # for the dash but can see I did not. It is 61712-08. I will appear as a console gasket assembly but it is the dash with the dash to tank gasket. Keep in mind this dash forces you to move your ignition switch from the neck to the dash unless you can fill the hole with something else the same size as the switch.
